test pipe woo's
Old Aug 14, 2003 | 06:33 AM
2000celicaspeed's Avatar
Default test pipe woo's
I just installed a test pipe last night.....Pulls noticably harder then befor.....got a CEL(i got the o2 sim to fix this) i am wondering if it is supposed to sounds rattly or if that is something loose...i havent got back under the car to check it out yet but i think it is somethign loose........anyone else with a test pipe have these issues?
Old Aug 14, 2003 | 06:41 AM
Xplosiv's Avatar
if your car is NA, a test pipe wont give you no more than 2 hp...and if your not running an aftermarket ECU, u should reset the stock ECU to let it learn the new setup...either way you wont have a noticabe gain from it.
Old Aug 14, 2003 | 06:48 AM
f20kills's Avatar
Mine rattles. I can only hear it with the windows up and music off. I searched to see if it was normal and read it was normal. I have stock exhaust and I felt no gains. Mine felt more like I lost top end. If I don't go FI soon, I'm tossing it.
Chris E.
Old Aug 14, 2003 | 07:37 AM
I have invidia exhuast and i can feel a very noticably harder pull on the low end........upper end feels the same but is loud as hell
Old Aug 14, 2003 | 08:11 AM
Gernby's Avatar
Former Sponsor
The noise is probably from an exhaust leak. Did you replace the 2 gaskets? Did you tighten the bolts in small increments to squish the rear gasket uniformly?
Old Aug 14, 2003 | 01:27 PM
f20kills's Avatar
I don't think mine is an exhaust leak. The best way to describe the sound is that it sounds hollow. My exhaust tone has not changed. Light throttle sounds deeper but WOT sounds stock.
Gernby, what type of exhaust do you have?
Old Aug 14, 2003 | 01:32 PM
Gernby's Avatar
Former Sponsor
Stock
Old Aug 14, 2003 | 03:51 PM
Asura's Avatar
[QUOTE]Originally posted by f20kills
[B]Mine rattles. I can only hear it with the windows up and music off.
Old Aug 14, 2003 | 04:10 PM
f20kills's Avatar
[QUOTE]Originally posted by Asura
[B]
The metallic rattling you get is from the testpipe itself.
Zach
23
Jul 18, 2010 02:21 PM
redfin8288
Jun 4, 2010 08:06 PM
91crxdx
Mar 6, 2010 04:39 PM
H2kBBAP2
May 20, 2009 07:47 AM
