THERE IS A PROBLEM WITH MY ENGINE
Old Feb 22, 2006 | 04:21 PM
batikan's Avatar
Default THERE IS A PROBLEM WITH MY ENGINE
TODAY, OUT OF NOWHERE, MY CAR STOPPED IN THE MIDDLE OF THE ROAD AND THEN THE ENGINE STARTED TO MAKE A WEIRD NOISE. I DROVE MY CAR BACK TO MY HOUSE WITHOUT PASSING 2000 RPM.
THERE IS DEFINITELY SOMETHING WRONG. I RECORDED A VIDEO OF THE CAR WHEN IT IS IN IDLE, AND THEN I PUSHED THE GAS A LITTLE.
PLEASE WATCH THE VIDEO AND TELL ME WHAT YOU THINK IS THE PROBLEM. AND WHAT I NEED TO DO TO REPAIR IT.
LINK TO VIDEO
Old Feb 22, 2006 | 04:29 PM
carman944's Avatar
Hey Batikan,
Sounds like possible valve train noise (ie, broken rocker, valve spring, etc) or maybe something even worse. Hard to tell exactly by just recorded sound.
Do NOT run engine until it can be professionally diagnosed or you may regret it. Find local Honda dealer with good reputation or independant if out of warranty (good rep also, ask around).
Mike
S2000 owner & auto tech 25+ years
Old Feb 22, 2006 | 04:32 PM
S2kracka's Avatar
Yeah she is definitely bad sounding, its tough to tell over the internet. Don't drive it and have it towed to a reputable dealership/shop/mechanic.
Old Feb 22, 2006 | 04:33 PM
batikan's Avatar
IF IT IS ONE OF THOSE PROBLEMS YOU HAVE MENTIONED, HOW MUCH WOULD IT COST TO REPAIR IT???? AND ALSO WHAT MIGHT BE THE REASON THE MADE THIS TO MY ENGINE???
Old Feb 22, 2006 | 04:49 PM
Incubus's Avatar
I'll bump your thread, but please take the caps lock off.
Old Feb 22, 2006 | 05:23 PM
moike's Avatar
WOW, it sounds like you shot the video in a construction zone! did you ever pull the codes for the check engine light because that may very well be your problem?
Old Feb 22, 2006 | 05:27 PM
batikan's Avatar
it was the exhaust. i got it repaired. i just didn't get the light resetted.
Old Feb 22, 2006 | 08:17 PM
WalkingDrunken's Avatar
As said when this was in the FS forum I think it is rod knocking also.
You asked if it would cost 3+. I would say yes you can always find a used shortblock or something that might save you money but if you don't do your own work then it's gonna be the labor that hurts. That is figuring that it is rod knock.
Sorry you have a problem but try to turn it into a positive situation. if your looking at a supercharger this might be a chance for you to get a built bottom end and have some fun for your boosting days.
Old Feb 22, 2006 | 09:00 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I replied in your FL thread.
Old Feb 22, 2006 | 09:11 PM
batikan's Avatar
where can i buy a built bottom end??
