Thermostat cover
Originally Posted by Stratocaster,Mar 12 2006, 12:36 PM
You want to know what the cover of the T-Stat is on the block? Metal. It is cast AL.
My wife has a Civic with a K20A2 in it. I had custom s/b upper/lower radiator hoses made for it. The upper hose worked fine, but the thermostat cover on the K20A2 is plastic, so the coupling on the lower radiator hose wouldn't work.
Before I invest some money in these custom hoses, I want to ensure the thermostat cover is metal.
Aluminium,
I converted mine to textile braided lines. The stainless lines tend to saw their way through things they touch, and they are heavy. I think I used dash 16 hoses and fittings with aluminum weld on.
The radiator may be your problem as from memory the are plastic fittings.
Chris.
Chris.
Originally Posted by chris_barry,Mar 12 2006, 05:04 PM
Aluminium,
Chris.
Chris.
vapors2k
Jan 17, 2003 02:07 PM
