Throttle Body Porting
Old Oct 8, 2005 | 05:04 PM
k22addict's Avatar
Default Throttle Body Porting
I recently port and polished my throttle body and bipassed the throtlle coolant lines with a splicer.I gained a significant amount of power and did the porting to spoon specs of 60 and 64mm top.Though recently my check engine light went on Problem: 2nd air injection system Incorrect air flow. It gave me a code p0411 and I figured it was due to the increased air I was getting- Has any one had the same problem ?
Old Oct 8, 2005 | 06:05 PM
Wisconsin S2k's Avatar
my guess is you switched your vacuum lines around. check the routing of the vacuum lines. it's not going to be because of the "increased air".
and how do you know you gained significant power? did you dyno it, or are you simply going by the typical cognitive dissonance.
Old Oct 8, 2005 | 08:07 PM
k22addict's Avatar
this is the first mod i've done to the car, and could feel the "significant" difference through feel...I dont need a dyno telling me that.N E wayz I didnt even touch the vaccum lines so are you sure this could still be the problem?
Old Oct 8, 2005 | 08:20 PM
sorry, but all you've "felt" is a placebo. no one can "feel" that small of a horsepower gain. unless you have super human sensitivity.
Old Oct 8, 2005 | 08:38 PM
Stratocaster's Avatar
p0411 is a cross vac line (Incorrect air flow). This is the most common code posted, and it normally is posted when someone installs a CAI, or uninstalls one.
Old Oct 8, 2005 | 11:50 PM
k22addict's Avatar
can i get rid of this problem or will i have to keep reseting the obd2?
Old Oct 9, 2005 | 03:17 AM
s2addict's Avatar
chuck?
Old Oct 9, 2005 | 04:37 AM
S2KPUDDYDAD's Avatar
Just switch the two lines agin/back and reset your cars ECU
Dame still at only 1.8 PPD when will I ever see 2.0
Old Oct 9, 2005 | 05:52 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Unless you are stating facts, don't encourage other to damage their car the way you have done.
Old Oct 9, 2005 | 06:35 AM
cdelena's Avatar
What you are feeling is an increase in throttle response. Since the diameter is larger than stock an equal application of throttle results in a larger increase is air. But when measured on a dyno you will probably find the same as others with ported TB's, no real increase in power.
