Throttle cable tension
Old Aug 18, 2015 | 08:57 AM
2Scars's Avatar
Default Throttle cable tension
I was fiddling under the hood the other day and I noticed the throttle cable was lax. How much tension should there be?
Old Aug 18, 2015 | 09:05 AM
solitarycheese's Avatar
4-6mm of free play - put a ruler perpendicular to the cable and press the cable down down to measure. You should be able to get 4-6mm of vertical travel before it starts pulling the butterfly valve.
Old Aug 18, 2015 | 09:08 AM
windhund116's Avatar
I tightened the cable... until it had a little play, at closed throttle. Like 1/8th inch free-play depression. Seem to work fine. I have a 2007.
Old Aug 18, 2015 | 09:16 AM
SheDrivesIt's Avatar
So the answer to your question is..... none. It should have slack.
Old Aug 18, 2015 | 10:42 AM
Slowcrash_101's Avatar
If there's tension the throttle plate won't close, and wear out the cable. Too much and it'll slow throttle response. There's a just right amount of slack.
Old Aug 18, 2015 | 10:43 AM
It works the same with the PPS?
Old Aug 19, 2015 | 09:19 AM
2Scars's Avatar
Thanks everyone. There was easily 3 cm slack! I tightened the cable so it's under 1 cm now. But the nuts are all the to the ends of the adjustment. Is there another adjustment point, or is the cable just stretched out?
Old Aug 19, 2015 | 09:23 AM
2Scars's Avatar
Confuse. "Not too much, not too little?"
Old Aug 19, 2015 | 01:36 PM
slalom44's Avatar
Top Answer: 1
you had over an inch of slack? That's way too much. 1cm is decent.
Old Aug 20, 2015 | 08:21 PM
2Scars's Avatar
Oh yea, it was redunculous! I was pretty sure that wasn't right. The warden has been driving, so she would never have noticed the slow throttle response. The adjustment nuts are all the way to the ends of the adjustment now. Is there another adjustment point, or is the cable just stretched out?
nightcrawler7188
Jun 4, 2020 08:42 PM
Shabadedoo
Dec 21, 2010 11:28 PM
Shabadedoo
Dec 21, 2010 07:28 PM
Squeezer
May 30, 2009 02:11 AM
J Roman
Nov 22, 2005 06:54 PM
