Throttle Position Sensor Jacked?
Old May 22, 2008 | 06:42 PM
Artisan7471's Avatar
Nice modeling, is that solid works? You have any other s2000 parts modled? If you send me a step file of this model, i can make you a custom mounting washer.
Old May 23, 2008 | 05:07 AM
S2Kart's Avatar
Yeah I'm using SolidWorks. I found a Delphi TPS that is only $23 vs. the $75 for the OmniPort. I'm going to see if the Delphi will work.
Here's a carbon fiber CAI I made.
Old May 23, 2008 | 08:02 AM
S2Kage's Avatar
Very nice work, what is step works?
Old May 23, 2008 | 08:54 PM
S2Kart's Avatar
step file, sort of a generic 3D data info that can be used to generate machining toolpath, automated machine inspection programming, yada yada
SolidWorks is a nice 3D modeling software
Old May 23, 2008 | 09:11 PM
Olegator's Avatar
Engineering rocks!
Old Jun 10, 2008 | 01:05 AM
NFRs2000NYC's Avatar
I have something weird....My car runs 110% fine, but I occasionally get TPS codes thrown here and there...usually when I'm backing out of my driveway. This could be attributed to my currently un-tuned greddy turbo kit, or this. Any thoughts?
Old Jun 10, 2008 | 08:55 AM
Olegator's Avatar
Had that on my integra with the greddy kit on....
Old Jun 11, 2008 | 06:20 AM
S2Kart's Avatar
Hmm. .. pretty sure the ULT is not doing anything with TPS V when the car is running off the stock ECU, and then when you are using the ULT (under boost according to MAP pressure) the ULT does not use the TPS sensor either.
I suppose you could un-plug/re-plug your harness in.
Old Jun 19, 2008 | 08:37 AM
silvers2k01's Avatar
Are you guys using the Omnipower TPS for the civic/integra?
Old Nov 15, 2008 | 11:01 AM
JoeyBalls's Avatar
What Sensor, I can't find one specifically for the S2000?
