"Thud" sound from rear....
Old May 18, 2009 | 07:13 PM
FISH22's Avatar
Default "Thud" sound from rear....
Installed some Koni yellows this past Saturday, and ever since the install, I noticed a faint/low thud from the rear right corner. Everything was installed correctly. All nuts and bolts torqued with the suspension preloaded. I even double checked some things tonight and can't seem to find what it might be.
The sound only happens on certain bumps, and it's not very consistent.
Any ideas?
Old May 19, 2009 | 03:30 AM
ahrmike's Avatar
is it a thud or is it a metallic thud/scrape/pop?
I had this - it was my dust boot that I bent during install. It took me 4 times to figure out what was wrong: taking it off/putting it on, etc etc.
Old May 19, 2009 | 06:54 AM
FISH22's Avatar
It's more of a hallow thud, possibly metallic. I will definitely take a look at the dust cover though. How was yours bent?
Old May 19, 2009 | 07:14 AM
Nickamsweet's Avatar
When you were under the car were there any marks anywhere that might help you locate the issue? Are the springs properly seated? When you hear the noise have you just gone over a hell of a bump? or is it a random noise?
Old May 19, 2009 | 07:47 AM
FISH22's Avatar
Yeah, I pretty much looked at everything. There seems to be no signs of any parts rubbing on anything. It usually happens on sharper bumps(usually potholes).
Old May 19, 2009 | 09:21 AM
jeffbrig's Avatar
Did you disconnect the rear swabar during the install, by any chance? If so, make sure the bolts connecting the bar to the endlinks are properly tightened. The nut in the endlink can spin, I had to grab it with a pair of skinny vice grips to tighten the bolt fully. When that was loose, I heard a little "thunk" going over bumps.
Old May 19, 2009 | 12:59 PM
FISH22's Avatar
Hmm, I didn't take the swaybar out, but I can check on it.
I'm actually starting to think it might be something inside the car, like a panel or something. I dunno.
Old May 19, 2009 | 02:48 PM
negcamber's Avatar
Did you load the spring when you torqued all the bolts down?
Old May 19, 2009 | 02:59 PM
FISH22's Avatar
Yep
Old May 19, 2009 | 03:28 PM
ahrmike's Avatar
The dust boot was dented only on the inside - I had to take off the rubber part and only then ddi I see that it was dented. I unbent it and it went away!
Apparently, during install I dropped it on something or hit it on something (when I was forcing the lower A-arms down, most likely). it looks perfect from the outside - I took the entire assembly out 3-4 times WITH more guys than just me - took the assembly apart a few times as well...til I finally just started taking everything apart - bushing, top hat, bushing, washer, dust boot, dust cover....and then I saw that it was bent -_-.
For me, it was a quiet 'thud/scrape' at first that got louder - I guess it got really bent after I hit a mean pothole and that caused it to scrape more.
