Ticking noise normal?
Old Jan 9, 2009 | 03:32 PM
Jacksparrow's Avatar
Default Ticking noise normal?
Hey guys I started to notice a ticking noise at idle coming from the engine its not very loud I cant hear it when the top/windows are up but I can hear it when the windows are down and the radio is off. Am I just paranoid or is this normal?
-Jacksparrow
Old Jan 9, 2009 | 03:35 PM
bgoetz's Avatar
If it is a new noise I would say something is going on. If so I would say it could be the timing chain tensioner starting to go.
Old Jan 9, 2009 | 04:24 PM
negcamber's Avatar
If it is just a faint high pitched tapping...it's probably just normal valve chatter. As a precaution, check your oil level.
And you might try having the valves adjusted.
If you can post a vid of what you are hearing, we might be able to tell more.
Old Jan 9, 2009 | 04:51 PM
Just got the head rebuild and I adjusted the valves so I think ill try seeing if its the tct.
Old Jan 10, 2009 | 09:55 PM
bposeley's Avatar
Excellent advice above - when the oil level drops (sometimes even as little as 1/2 a quart low) you will start to be able to hear the valves working. Check your oil, I bet it's low.
Old Jan 11, 2009 | 05:17 AM
clag's Avatar
card in the spokes - TCT
ticking - injectors
sewing machine chatter - valves
Old Jan 11, 2009 | 08:52 PM
s2kboiii's Avatar
I've also realized this ticking sound on my car, however, it doesn't tick when i first start the car. It usually waits till after a bit of driving before the ticking starts and i can only hear it from the inside of the car. I've popped the hood and can't hear the same ticking.
I put 5 quarts of amsoil. I know we should do 5.1Q but would that .1 really make that ticking sound?
Also, the ticking noise starting after one night were I accidentally over-revved 3rd gear. Could that have caused it??
Old Jan 11, 2009 | 09:22 PM
bposeley's Avatar
Did you overrev it into "redline" by simply not shifting right away or did you mechanically over-revv it (being in 3rd at high RPM and shift to 2nd instead of 4th).
Old Jan 12, 2009 | 05:52 AM
http://www.youtube.com/watch?v=-H4EPpsKfOw my ticking sounds like this. Its not very loud and can only be heard if you listen real closely so im gonna assume its valvetrain noise. I check the oil everytime i start up the car and the oil level is fine.
Old Jan 12, 2009 | 06:58 AM
Tjs S2k's Avatar
the video above sounds fine, mine does that sound along with this one
http://www.youtube.com/watch?v=Y8hYA...eature=related
(new TCT, valves adjusted, oil level fine, honda says its normal) ha
