Tie rod ends
Old Jan 29, 2024 | 05:16 AM
Dibsen's Avatar
Default Tie rod ends
What's everyone using for tie rod ends?
I have read a few things about the Megan ones. ($100ish) set
Looks like OE Honda are about $70 (for 1)
Then Hard race $200 set
Also,
Would the Megan or Hard Race DQ me from SCCA Street class as a "non-approved, performance part". I keep getting caught with details, I thought I could run AP2 wheels but because they are wider, I can not. It's ok to increase rim size by 1" but the section width needs to be the same. That's why I went back to AP1 wheels.
Again, my use is Street Class auto cross so I need to stay stock on most things. I think I am answering my own question. Think I am getting caught up on the fact that I like spherical bearings and upgrading parts as they need replacing. This whole "staying stock" thing is new territory for me.
Old Jan 29, 2024 | 06:43 AM
B serious's Avatar
If your tie rod ends are worn out (are they?), then the factory replacement is the best choice.
Unless you have some specific reason, I wouldn't buy ones with adjustable studs.
If you're talking about the Megan or HR ones that are just OE replacements...there's nothing wrong with them. They're good OE replacements. But if a factory replacement part is available....never go aftermarket.
Old Feb 1, 2024 | 04:35 AM
Slowcrash_101's Avatar
Inner or outer? Also Honda doesn't make tie rod ends, or inners. Nothing wrong with Hard Race, I would gladly replace OEM suspension bushings, and ball joints with anything Hard Race with confidence.
DLoS2K
May 2, 2022 02:52 PM
SilverSpyder
Jan 6, 2019 09:49 AM
vincengf
Nov 30, 2013 10:25 AM
boyguan
Jul 31, 2012 04:50 AM
starbai
Oct 29, 2008 09:19 AM
