Tilt Steering wheel.....?
Old Feb 19, 2005 | 06:56 AM
derek14's Avatar
Default Tilt Steering wheel.....?
I know there has to some of you other guys out there that like your steering wheel low and close. I always wished there was a tilt wheel on the S2k's. Anyone ever thought of modifying it, possibly using other Honda partsto make a tilt wheel? Just an idea, lets see what we can get for input
Derek
Old Feb 19, 2005 | 08:54 AM
Slows2k's Avatar
You can add spacers/washers under the column mounts to lower the wheel, but there isn't much you can do to raise it. The S2k's steering column isn't even close to the same dimensions as other Honda columns. You would also run into clearance issues with the gauge cluster to tilt the wheel up.
DeletedUser05.22.20
May 13, 2015 12:44 PM
S2KBert
Feb 28, 2015 11:20 PM
josh7owens
Feb 6, 2010 11:30 AM
