Timing Belt..when to change it?
Old Dec 6, 2005 | 08:53 AM
greys2k's Avatar
Default Timing Belt..when to change it?
Hey guys...just wondeirng when your supposed to change the timing belt on the s2k? I might get severly flamed for this because some guy said that he thinks there might actually be a timing chain in the s2k and not a belt...so maybe it doesn't need ot be changed (if its a chain)
I'll take the chance of being flamed...and just ask at what km range do I need to change the belt at? and how much does it normally cost??
thank you,
Kyle
Old Dec 6, 2005 | 09:06 AM
jasonw's Avatar
It's supposed to last for the life of the engine - and it is a chain.
Old Dec 6, 2005 | 09:34 AM
ToeKneeC's Avatar
Old Dec 6, 2005 | 09:47 AM
cap1's Avatar
So no change required?
Old Dec 6, 2005 | 09:50 AM
DOUGHS2K's Avatar
Old Dec 6, 2005 | 10:06 AM
highligter's Avatar
chain should last forever.
Old Dec 6, 2005 | 10:24 AM
stitos2k's Avatar
It may need an ADJUSTMENT every 60k miles or so, but you don't replace it.
Old Dec 6, 2005 | 10:27 AM
xviper's Avatar
It's an automatic tensioner. No adjustments possible, however, the tensioner has been known to go bad.
Old Dec 6, 2005 | 03:13 PM
mikegarrison's Avatar
Nothing lasts forever. (Except maybe visiting relatives.)
The chain should probably last the life of the engine, but if you were doing a complete engine rebuild a new chain would be a reasonable idea.
Old Dec 6, 2005 | 05:47 PM
greys2k's Avatar
beautiful! thanks guy!
I know with hondas...(well im sure any car) that when and if the timing belt brakes they can bend valves and mess things up pretty good..but im sure with the s2k..if it was a belt and was to break it woudl really mess things up...so at least I dont need ot worry about fixing it! yay thank you!
