toda cams in FI application
Has anyone used the toda cams in a FI application, more interested in supercharged application?
If so, what are your thoughts on these? gains?
They sound like a great product, but i have heard nothing on them regarding their effectiveness in a forced induction application.
No, its overlap that is bad for boost situations. Last I checked, most cams for DSM's and other turbo cars have higher lift. They don't cause problems other than rough idle.
The Toda cams would be bad for FI, simply because they increase overlap over stock (As most NA cams do, if I remember correctly), and if you have the exhaust ports open at the same time as the intake ports, with FI the pressure escapes out the exhaust.
Blake
Blake
I know it would be expensive for the first set, but shouldn't a company like Crower be able to make a set of cams for this engine that is specific to FI? I would think we could go to them and get something ground that, using their knowledge and research, would significantly help a FI motor.
Coming from a small block Chevy motor world, I know the cams we had done for the blower were a whole lot different and they made a lot of difference.
-YS
-YS
[QUOTE]Originally posted by Yellow Streak
[B]I know it would be expensive for the first set, but shouldn't a company like Crower be able to make a set of cams for this engine that is specific to FI?
