Torque Setting for PCV Valve on Ap2 Cover ?
Does anyone know the torque setting to install the screw in metal type of pcv valve on an ap2 valvecover ?. I have an 04-05 ap2 valvecover on my ap1 and my service manual doesn't show the ap2 pcv valve. I know most things that screw into the valvecover are about 8.7 ft lbs of torque, just want to confirm the setting if possible. I did a search and nothing came up. Thanks for any replies.
interesting...i installed an ap2 valve cover on my ap1, and i can't remember if i found the torque setting, but something in my head tells me i saw 14 ft/lb.
but when i installed it, i just tightened it until it felt right.
Originally Posted by JFUSION,Mar 11 2010, 04:39 AM
thanks for the reply on this. Yeah since the pcv valve uses a crush washer perhaps it could be in the 14 ft lb range, I don't want to over-torque it though. Perhaps I will just snug it down if I can't confiirm the exact number. Would it be listed in an owner's manual for an Ap2 ?. thanks for the reply.
i didn't install it with a washer...
Originally Posted by jyeung528,Mar 11 2010, 10:17 AM
yours came with a separate crush washer?
Originally Posted by jyeung528,Mar 11 2010, 10:55 AM
fuggit.
i'll leave mine as it is.
To keep things safe I torqued mine down to 8.7 ft lbs, like all the other bolts on the valvecover, hopefully that is safe.
