torque specs
Old Feb 21, 2017 | 11:48 AM
Classic JDM's Avatar
Default torque specs
Anybody know the torque spec for the below bolt with the tool in it? I've noticed a small amount of oil leaking from around it, so I want to make sure it's tight. Thanks for your help!
Old Feb 21, 2017 | 01:07 PM
munster87's Avatar
I believe that one is suppose to be 22 ft lbs
Old Feb 21, 2017 | 01:18 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There is an aluminum washer on that plug just like the drain bolt. Very rare for that to leak, no pressure there.
Also note your TCT is missing a bolt, but you may be working on it currently.
Old Feb 21, 2017 | 01:20 PM
Billman250's Avatar
Top Answer: 1
Very rare for that plug to leak, there is no pressure there. It has an alum washer just like the oil drain bolt.
Old Feb 21, 2017 | 01:53 PM
Thanks! It's just a picture I found while searching for the torque specs, so it's not actually my car. Billman, can you confirm that the bolt needs to be torqued to 22 ft lbs?
Old Feb 22, 2017 | 03:26 AM
Slowcrash_101's Avatar
Well if that plug has been removed before, you may need a new washer to stop the leak.
Old Feb 24, 2017 | 02:25 PM
jyeung528's Avatar
is it tight as it is? if you're not replacing the washer, give it a nice tug?
if you're replacing the washer, 33 ft/lb would be nice and tight.
if you're looking for factory torque spec...there's an ap1 service manual that is widely circulated for download on the world wide web and you can search for it there.
Old Feb 24, 2017 | 05:38 PM
windhund116's Avatar
My bet is the washer should be replaced, to get the best seal. 33ft-lbs seems correct, for an 8mm Allen head hex key.
Old Feb 24, 2017 | 06:17 PM
Billman250's Avatar
Top Answer: 1
22 is more than enough.
Old Feb 24, 2017 | 08:00 PM
Yeah, more reasonable. Guess as long as new washer is starting to smoosh, you are ok.
