Torque wrench
Old May 24, 2002 | 04:16 PM
S2KFanatic's Avatar
Default Torque wrench
I'm in the market for a torque wrench...as I'm going to change my own oil, etc. I stopped by Sears, & they have a digital 3/8" drive that works w/5-80 ft lbs for $90. I want to get one that is good overall(lug nuts to spark plugs)....is this a wise choice?
Old May 24, 2002 | 04:24 PM
xviper's Avatar
If you can afford it, you should get 2 ranges of wrenches. You really shouldn't be trying to crank at the limit of the wrench like you would when you do the lug nuts (80#). Also, using it at the lower end like for the spark plugs (13# by the book) might not be too accurate either. I don't know what it would do its accuracy if you do lug nuts and then crank it down to do spark plugs after that. I have a 1/2" drive torque wrench for lug nuts. 3/8" drive for lugs might not be strong enough, especially if you are going to use it for other cars where lug torques can be over 100#.
Old May 24, 2002 | 04:29 PM
Silver Bullet's Avatar
That's probably a good general-purpose choice.
I have the same torque wrench but with a 1/2" drive. I wish I got the 3/8" drive because the range on mine doesn't go low enough for torquing spark plugs (25-250 lbs). I got mine mainly for torquing lug nuts.
A smaller 3/8" drive might not be accurate enough to properly torque lug nuts since you'd be approaching the upper end of the wrench's limit.
You might want to consider a wrench that's calibrated to in-pounds instead of foot-pounds. It'll be more accurate for smaller jobs like spark plugs and if you can simply diviide/multiply by 12 to convert to/from foot-pounds.
Old May 24, 2002 | 04:34 PM
XTC at 9K's Avatar
Snap-On all the way!! 3/8 5-75 lb. ft. with 0.5 lb. ft increments!
and another 3/8 20-100 lb. ft. also in 0.5 lb. ft. increments!
They can also take care of calibration too!
Old May 25, 2002 | 07:48 AM
synapse's Avatar
I agree with XTC,
Ebay all the way, you will find lots for decent prices
Old May 25, 2002 | 08:20 AM
boiler's Avatar
[QUOTE]Originally posted by xviper
[B]If you can afford it, you should get 2 ranges of wrenches.
Old May 28, 2002 | 07:42 AM
S2KFanatic's Avatar
Well, I picked one up at Lowe's! It's the Kobalt line, which is actually made by Snap-on. 10-100 ft lbs in 1/2 lb increments. Lifetime warranty, & comes w/calibration papers...works like a charm. Thanks for all the advice!
Old May 28, 2002 | 12:23 PM
iatacs19's Avatar
how much was it?
Old May 28, 2002 | 01:03 PM
KenS2K's Avatar
Originally posted by iatacs19
how much was it?
Local Lowes price:
Kobalt 3/8" 10-100lbs. $89.94
Kobalt 1/2" 30-150lbs. $109.91
Old May 28, 2002 | 09:40 PM
Utah S2K's Avatar
[QUOTE]Originally posted by S2KFanatic
[B]Well, I picked one up at Lowe's!
