TPMS Woes
Old Dec 4, 2009 | 01:08 PM
offroad2000's Avatar
Yep. Every time the weather changes (either gets colder or gets warmer), we get customers coming in with low tire lights.
Old Dec 4, 2009 | 01:18 PM
berlinablackie's Avatar
Oh yeah, I overlooked something in your original post. Be careful driving on RE050s in freezing temps, they become real slick making it easier to spin the car...I learned the hard way.
Old Dec 4, 2009 | 06:35 PM
fatjoe10's Avatar
^ I concur.. 3/32nds RE050's in freezing temps makes for an interesting ride.
Old Dec 4, 2009 | 07:29 PM
jeggy's Avatar
Originally Posted by berlinablackie,Dec 4 2009, 09:48 AM
Not sure if it works in the S2000 (mine is '03 w/o TPMS), but I removed the TPMS sensors out of my 350Z wheels and the dash light does not illuminate. Maybe someone with an S has done this and can validate if it works.
i have an 08 CR as well as a local owner.
we both are on wheels that are NOT equiped with tire pressure monitors.
both our cars are displaying "TPMS" on the dash.
Old Dec 4, 2009 | 08:06 PM
2poor2mod's Avatar
So it was 82 degrees farenheit out and no snow huh? adjust your tire presures and you'll be ok.
Old Dec 4, 2009 | 09:36 PM
Nofar's Avatar
Hey Guys,
I'm a mechanical engineer and design TPMS systems for Chrysler, but not Honda. They're very similar though. There's a sensor incorporated into the valve stem that transmits at specific intervals. This is a NHTSA safety standard that is mandatory on all vehicles starting in 2009+. Some manufacturers have gotten started on TPMS much earlier though, like Chrysler, who's had it since 2005, at least my from company.
When it's colder outside the the air is more dense and the pressure inside the tire drops, even without adding or removing air. It's the same amount of air in the tire, it just takes up less volume, hence less pressure in the tire. The sensors typically can read a pressure with a tolerance of +/- 1psi, so if you were at 32psi it may be between 32-33psi and not trigger the light to come on the dash. +/- 1psi is pretty typical from the different systems that I've benchmarked.
Needless to say, if you're at 26 psi, you simply need to fill your tires with air and bring them back to 32psi, or whatever you usually use. It's really that simple. Under inflated tires are a serious problem as they change vehicle dynamics and the car will not accelerate, handle, or worse, will not brake as optimally as if the tires were pressurized properly. Hope this helps.
Regards,
Christopher
Old Dec 7, 2009 | 02:13 PM
Tech7427's Avatar
26.5-27psi is the common threshold to setting the light on im seeing throughout honda/acura models.. its getting colder out here and alot of customers are coming in with tpms lights saying its only when its cold out..case in point..
Jay2000
Oct 25, 2013 05:02 AM
jhp012
May 1, 2009 02:13 PM
Mike in Atlanta
Nov 20, 2001 07:40 AM
GameDev
Sep 15, 2001 02:35 PM
