Tram-Lining
Old Jan 26, 2001 | 07:29 AM
pfb's Avatar
pfb
Lately I've been noticing more tram-lining with my S2K. (a dartyness and tendency to follow ruts and wear grooves in the road)
Four things are different:
1. Spoon X-Brace
2. Mugen Sway Bar
3. Very worn front tires, newish rear tires
4. 38 psi f&r
Any idea which of these might be causing the recent increase? How much tram-lining do you experience on your S2K's?
Old Jan 26, 2001 | 08:01 AM
The Reverend's Avatar
Old Jan 26, 2001 | 09:03 AM
Prolene's Avatar
When my A032Rs wore down I got ALOT of tram lining. I thought the alignment was shot until I realized the new tires cured that.
Old Jan 27, 2001 | 01:59 AM
2kturkey's Avatar
I always run 39psi, tyres are well worn and due for replacement imminently - no x-brace, no sway bar and never a hint of tramlining. I'd say 1 or 2.
Old Jan 27, 2001 | 04:07 AM
charlie's Avatar
#4 I have had the same prob since increasing tire pressure. I am going to lower it back to spec and see if it helps
Old Jan 28, 2001 | 09:29 AM
Utah S2K's Avatar
The S2K is already plenty stiff. The X-Brace and sway bars are great for the track.....but the street? Honda pays its engineers a lot and Honda spends a lot on R&D....it amazes me that people spend so much on "accessories" which usually detract from street performance which is how the S2K was targeted. My personel favorite is guys that go to +3 tires on the street.......
No tram problems here, stock Honda engineering all the way.....
Old Jan 29, 2001 | 02:01 PM
RT's Avatar
RT
Utah, I'm sure pfb would like to thank you for all your help
My guess is #3 based on experience with other cars (sorry no first hand probs w/ S2000) but #4 is so easy to rule out you ought to do some experimenting.
BTW, my S2000 does it the least out of the cars I currently drive on a regular basis.
Old Feb 3, 2001 | 08:17 AM
jschmidt's Avatar
All of the above. Stiffness increases responsiveness (right, like it's a feature) to road imperfections. Old tires reduce resistance to road imperfections.
KGB
Aug 19, 2003 08:10 AM
Tanqueray
Jan 7, 2002 10:25 PM
Squeezer
Oct 15, 2001 06:55 PM
lvs2k
Feb 24, 2001 02:35 PM
etgar
Nov 16, 2000 07:48 AM
