Transmission Fluid Change DIY
Old May 13, 2009 | 09:33 PM
  #71
Ezekiel55's Avatar
Nice write up. thanks.
Old May 14, 2009 | 06:58 AM
  #72
INTJ's Avatar
Originally Posted by Kirpich,Feb 14 2009, 08:46 AM
Well, I did it, and the tranny is notchier than before. ? Colder ambient temps? It seems notchier even when it's warmed up.
1. Canuckian, just order it from a US vendor, but use US mail NOT UPS unless you want a 40 add on fee. Who knows what sort of can tire crap they are selling you.
2. Right after I change tranny fluids it often feels odd right away. I don't know the chemical reason (if any), but I guess the old fluid just shears down to a lower grade which feels better at startup? (I don't agree about carbon-synchro resaturation.) Give it two weeks. But check the bottle, lots of MT-I out there and god forbid you got dual pump.
Old May 15, 2009 | 01:23 PM
  #73
thomsbrain's Avatar
Followed this DIY and changed my own transmission fluid with no problems. Thanks for the writeup.
Edit after a day: Shifts are noticeably smoother now!
Old Jul 14, 2009 | 08:08 AM
  #74
Kirpich's Avatar
[QUOTE=istdercollen,Feb 14 2009, 11:54 AM] ^ did you verify you used the right oil?
Old Oct 4, 2009 | 02:05 PM
  #75
REV59K's Avatar
Great diy , I'll use this info for sure,you saved me some $$$$$$
Cheers.
Old Oct 5, 2009 | 07:06 AM
  #76
JackS's Avatar
I tried a small hand pump doing a diff change and what a mess. I'm guessing the size of the tubing was a 1/4in and the tubing is slipped over the nipple on the hand pump. The resistance when trying to pump this rather heavy weight lube can (and did in my case) force the tubing off the nipple with the resulting mess. If your going to use a pump, secure the tubing to the nipple using a piece or two of wire and be patient when pumping or perhaps, find a pump with larger diameter tubing to begin with. My next diff change I'm going to use a large rubber bulb syringe. It should be much easier and faster and cleaner than the standard hand pump.
Old Oct 5, 2009 | 07:57 AM
  #77
INTJ's Avatar
Warm the fluid first in the sink. A small clamp could help, but I find that the bulb style trapps fluid in the bulb.
Old Jan 9, 2010 | 11:00 PM
  #78
cabba's Avatar
Awesome tutorial!
Greatly appreciate it!
Old Feb 16, 2010 | 03:05 PM
  #79
cabba's Avatar
Where can I get the washers for the diff?
Old Feb 16, 2010 | 05:12 PM
  #80
2Kaputnik's Avatar
Your dealer, or an online source like H and A.
http://www.handa-accessories.com/
