trunk spring removal
Old Mar 10, 2006 | 09:29 AM
jin6's Avatar
Default trunk spring removal
how do you remove the springs in the trunk? do i need a special tools?
Old Mar 10, 2006 | 10:08 AM
SIIK2NR's Avatar
There is a specialty tool that cost $19.60 + shipping, but you can use a big screwdriver to pry the bars.
Be careful when doing it with the screwdriver.
Old Mar 10, 2006 | 02:25 PM
jeggy's Avatar
i wouldnt try it unless im wearing metal armor. go with the tool. it'll get the job done in like 2 minutes. safely too.
with the screwdriver you risk the spring flying off and poping you in the arm or even the nads if you aint got help holding the trunk lid up.
Old Mar 10, 2006 | 03:21 PM
cfcrafting's Avatar
just remove the hinges from the body
Old Mar 10, 2006 | 05:07 PM
chicagos2k's Avatar
I removed the springs by hand.
It took two minutes. Not hard, just need a little elbow grease.
I don't recommend this. I walked away with two pretty deep cuts in both my hands.
Yea, I'm not very smart. I didn't stop after the first one cut me.
Old Mar 11, 2006 | 04:47 AM
Harpoon's Avatar
Are you changing the springs because you got a rear spoiler? I did and wished I left the factory springs in. The stronger ones don't fit as well and need to be adjusted about once a month to not squeak when opening. Also, they're not really that stronger. The original springs are strong enough for the spoiler's additional weight.
Old Mar 11, 2006 | 05:01 AM
Slows2k's Avatar
A pair of vice grips can work if you don't have the special tool. Beware of flying trunk springs though.
Old Mar 11, 2006 | 07:46 AM
04RioS2k's Avatar
I used me a screw driver to pry it out...no cuts no nothing.....now putting it back in might be a different story....
Old Mar 12, 2006 | 10:43 AM
Smokings2K's Avatar
Banned
i will change mine tom, but il definitely consider Harpoo's idea of leaving the spring because its not that i open the trunk as much i open the door rather than running into more issues
JawKnee
Nov 21, 2009 02:51 PM
Rookieboy
Aug 17, 2009 04:12 PM
jin6
Mar 10, 2006 12:22 PM
Tony Yeung
May 16, 2005 10:18 PM
jedraz
Apr 25, 2002 04:09 PM
