Trunk Wont Open
Old Aug 13, 2008 | 04:46 PM
Kane_X3's Avatar
Thumbs up Trunk Wont Open
well, my trunk wont open if i press the button in the glove box or on the keychain. i looked at the fuse box and didnt find anything that said trunk release.
what am i missing?
my trunk still opens when i use the key, but i have been so spoiled with just pressing a button
HELP!!!
Old Aug 13, 2008 | 04:48 PM
Kane_X3's Avatar
nevermind. think i found it. be back to see if it worked
Old Aug 13, 2008 | 04:54 PM
Kane_X3's Avatar
damn it. thought it was the ACC Socket fuse but it was fine. any help would be appreciated
Old Aug 13, 2008 | 10:15 PM
StealthimageS2k's Avatar
I have the same problem but my buttom stopped working after I had my alarm installed with the trunk release on the remote so I kinda just foregot about it but a solution would be great!!
Old Aug 14, 2008 | 04:45 PM
Kane_X3's Avatar
anybody?
Old Aug 14, 2008 | 05:00 PM
nnkfws333's Avatar
I had this issue and actually brought in my car to the shop that installed the alarm. They said a fuse was blown and replaced it. Now my alarm remote + button in the car work. Not sure which fuse though.
Old Aug 14, 2008 | 05:04 PM
Supra-holic's Avatar
Just throwing this out there, might not help you but...
There are two long thin bars that connect to the trunk that provide tension, like a leaf spring to pop up the trunk when it is released.
You might want to inspect those to make sure they are working correctly. They should run into each other when you are closing the trunk.
Easy way to check is to push the button on the key chain and lift up on the trunk with your hand to see if it opens.
Otherwise you might need to look at the release mechanism.
Old Aug 14, 2008 | 06:13 PM
Nickamsweet's Avatar
Open the boot...and then click to open the boot...you should hear the mechanism working... if it's to do with that then the leaf spring type actuator that pushes the boot open could be sticking or worn (if poss :s)
If you can't hear the mechanism check a wiring manual (if poss) to track the wiring back. Most likely a fuse, could be a loose connection or a knackered servo mechanism...
Old Aug 15, 2008 | 02:47 PM
Kane_X3's Avatar
not the tension bars. wheni open it with the key the trunk opens with ease and doesnt close on its own. and they do cross in the middle.
i clicked the key button while it was closed and lifted up, still locked.
i opened the lid and clicked the button, didnt hear anything.
i checked the ACC socket fuse but its fine, even replaced it to make sure. or is it another fuse i should look it?
i guess it has to be a wiring problem
Old Aug 15, 2008 | 03:36 PM
HondaS's Avatar
did you check the kick panel fuse box?
