trying to replace clutch
Old Jan 26, 2010 | 11:36 AM
xasrielx's Avatar
Default trying to replace clutch
im trying to replace the clutch. i undid the tranny mount. electrical connections. undid the clutch line and shift fork. and i was about to undo the driveshaft. but the allen bolts are stripped to hell.
anybody know a good technique to get them off? im having some trouble with it
Old Jan 26, 2010 | 11:42 AM
aresk3b's Avatar
soak them with wd40 or pb blaster
u can
1 try to rotate them with a vise grip
2 try to file some to have 2 parallel sides then u could use a metric open wrench
3 cut them off with a dremel and then extract the tucks
4 cut an edge across to use a big screwdriver (but I guess u can't fit one in there)
5 u can weld a nut over it and use the nut to unscrew them
be creative. and good luck
Old Jan 26, 2010 | 05:15 PM
japhethwar's Avatar
I have had good luck using a torx bit in stripped allen heads. Drive in a slightly large torx bit with a hammer. Usually works pretty well.
Old Jan 27, 2010 | 05:30 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Slightly larger torx bit, AND vise grip on the outside. There's plenty to grab.
Pull the vise grips and the torx together. I have seen this many times and this method has never failed yet.
Old Jan 27, 2010 | 06:03 AM
emac0408's Avatar
works every time....
ktwenty
Apr 10, 2014 10:21 AM
westfield147
Jan 12, 2012 11:52 AM
terahertz
Oct 16, 2011 10:42 PM
splatter85
Apr 14, 2010 11:55 PM
