Tuning- Catless vs. Cat
Old May 8, 2005 | 08:40 PM
Hamiy's Avatar
Default Tuning- Catless vs. Cat
I have a few question about what to do when I get my setup tuned. Most likely going to be tuned with AEM EMS or possible VAFCII.
If I get it tuned with a test-pipe and no cat, will it make better gains than w/ a cat? Or will it just be the 1-3hp same gain?
Lets say I get it tuned without the cat. What will happen if I have to put the cat back on for a day? I am guessing this will be forcing too much air out the back and their will be a pressure buildup in the cat?
Thanks for any info
Old May 9, 2005 | 01:53 AM
m@dm@n's Avatar
Banned
car isn't turbocharged, leave the cat in.
Old May 9, 2005 | 07:43 AM
S2kracka's Avatar
People have been seeing nice gains by running a testpipe instead of the cat even while close to stock.
Old May 9, 2005 | 02:54 PM
bluesaint's Avatar
you will have to re-tune it once u put test-pipe in. the exhaust flow rate will increase, which means your A/F ratio is effected.
Old May 9, 2005 | 08:40 PM
Hamiy's Avatar
What would happen if I tune it with the testpipe and then put the cat back on (for less than a day?)
Old May 9, 2005 | 09:05 PM
s2kjay's Avatar
how would i just take the cats off and im close to stock
would this be a bad thing to do..i just wanted to experiment and see how loud the car will be if i take the exhausts off
Old May 12, 2005 | 07:51 PM
Hamiy's Avatar
Heres the new question for those who have used a EMS (VAFC2 or AEM EMS)
If I tune it with the testpipe and then need to put the cat on, I will need to reset the ECU. If I then decide to put the testpipe back on, do I need to get it dyno tuned again or can I just remember the settings I used before and do this manually? Do you need the maps or whatever to tune or can you do it bye yourself? I know its unsafe to tune by yourself normally, but if I already know the settings I want, it should be fine.
Any suggestions? Can I actually tune on my own after I get the correct settings from a professional?
Old May 13, 2005 | 03:17 AM
m@dm@n's Avatar
Banned
what gains are people seeing with a test pipe?
Old May 13, 2005 | 08:04 AM
1Ferris's Avatar
The S is louder than hell with the cat and exhaust off. Completely impossible to hide from the cops if they are even a block away.
Old May 13, 2005 | 11:07 AM
AJ PwR's Avatar
About 3-4whp with a stock exhaust.
