Turning check engine light off
Old Aug 9, 2005 | 02:07 PM
gochuxsaurus's Avatar
Default Turning check engine light off
I just recently changed my oil when the check engine light came on...I was wondering how do I turn the check engine light off?
Old Aug 9, 2005 | 02:10 PM
SIIK2NR's Avatar
You better check why the check engine light came on before turning it off.
Changing oil shouldn't turn it on.
Old Aug 9, 2005 | 02:11 PM
The engine check light went on because I needed an oil change...so when I got it...it still is on...so don't I need to reset the ecu to turn it off?
Old Aug 9, 2005 | 02:21 PM
Empedocles99's Avatar
Check engine or maintenance required light?
Old Aug 9, 2005 | 02:25 PM
mikegarrison's Avatar
No, the check engine light did not come on "because you needed an oil change".
There is a light labeled "Check Engine". There is a light labeled "Maintenance Required". These are not the same light.
If it actually was your "check engine" light that came on, you have a problem that is almost certainly unrelated to oil.
Old Aug 9, 2005 | 02:59 PM
xviper's Avatar
"Patience is a virtue."
You posted this in a thread, then only 4 minutes later, you start a new thread asking the same question?
Like these guys said, if it's the CEL, you don't just reset it without knowing why it came on and it doesn't come on just because you needed an oil change.
(I answered you in the other thread.)
Old Aug 9, 2005 | 03:13 PM
Wisconsin S2k's Avatar
so in other words.
do you have a "maintenance required" light on? or is it the ACTUAL check engine light?
Old Aug 9, 2005 | 07:41 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
This is the check engine light, but it doesn't say "check" in the middle:
The other light is the maintenence light, and actually says "Maint Reqd"
Old Aug 9, 2005 | 09:26 PM
xenosis's Avatar
like everyone else said, you shouldn't be getting a check engine light....
check to see why it came on...
to turn it off its in the manual, but you should really get it checked out
Old Aug 10, 2005 | 12:48 AM
toycar8's Avatar
what should come out when you forget to replace your gas cap?
