UK specs
Old Sep 26, 2008 | 12:28 PM
teanza's Avatar
Default UK specs
i posted this in s2k talk; think here would b better
i have searched 4 hours! i am going tuesday. i keep seeing either .66 total rear toe or .40 total rear toe. which 1 is it?!
i am doing -2 rear camber/-1 front camber. lowered on espelirs, run direzza 255's, & MAY do occasional tracking.
assistance?! thank u!
~tina~
Old Sep 26, 2008 | 02:41 PM
roflitzjinno's Avatar
Old Sep 26, 2008 | 02:43 PM
s2k dre's Avatar
i told u tina!! .40 total toe is fine!!!
Old Sep 26, 2008 | 08:44 PM
MUAY_THAIerd's Avatar
Remember that the uk spec sheet is in minutes. so it is .66 total toe in the rear
Old Sep 26, 2008 | 11:48 PM
teanza's Avatar
yes that was my problem; people were converting in different ways. i saw that sheet 1000000x but the interpretations were scattered. .66 is the deal 4 me. thanx!
~tina~
Old Sep 27, 2008 | 05:14 AM
Nyther's Avatar
the guys at thw alignment didnt managed to get my rear camber at -2 degrees without getting the toe out of specs.... the best job they could do is .40 total toe and -1.3 degrees camber in the rear... they told me they couldnt do more because the adjustments were on max already.. I'm lowered on apex springs 25mm....
What do i need to get my camber to -2 without messing the toe up? get the J's/T1R adjustable rear anti-bumpsteer kit?
Old Sep 27, 2008 | 06:22 AM
Vanishing Point's Avatar
Correct me if I'm wrong on this, but I'm under the impression the UK specs call for
the rear toe to be: 0 degrees 20" (left and right side). When you convert inches to degrees the toe is +0.16 degrees per side for a total of +0.32 degrees.
Old Sep 27, 2008 | 03:24 PM
teanza's Avatar
ha! that's y i needed to make this thread; so confused!
~tina~
Old Sep 28, 2008 | 05:19 PM
teanza's Avatar
so .32, .40, .66?! AH!
~tina~
Old Sep 28, 2008 | 05:38 PM
tekstar's Avatar
as i posted in your other thread.. 0.66
