under powerd help!needed!
Old Nov 17, 2008 | 10:21 AM
L600MEY's Avatar
Default under powerd help!needed!
the car is an 00 f20 bog standard!
engine power 209.4bhp
wheel power 146.8bhp
torque 175.6nm
as the car hits v-tech you can hear it come in but on the graph the torque stays at around 160 and doesnt go up im stumped to be honest, any ideas welcome please cheers
Old Nov 17, 2008 | 10:47 AM
loftust's Avatar
Check your oil levels and air filter.
Old Nov 17, 2008 | 10:56 AM
L600MEY's Avatar
new filter mate and oil bin changed month and a half ago and levels are good mate
didnt no weather a full out service might help but surely not that much!
Old Nov 17, 2008 | 11:03 AM
iDomN8U's Avatar
Check the Map sensor
But with the vtec cam engaged, you should see a pretty flat torque curve.
Post the graph
Old Nov 17, 2008 | 11:06 AM
L600MEY's Avatar
will do asap mate
Old Nov 17, 2008 | 11:17 AM
L600MEY's Avatar
not the best as my scanner aint working so took a pic
blue line 2nd from bottom is wheel power
next one up is engine power
and the top one is torque
Old Nov 17, 2008 | 11:30 AM
KchaoS2K's Avatar
milage?
Old Nov 17, 2008 | 11:31 AM
iDomN8U's Avatar
Pull out the Map sensor, it resides on the throttle body. clean out the contact and plug it back in.
Strange thing is your HP is climbing as if vtec has engaged.
210 bhp = 180ish whp? if so you're engine looks healthy and vtec is engaging because without it you wouldn't see anywhere near those #'s
Old Nov 17, 2008 | 11:32 AM
iDomN8U's Avatar
Also, do you have an aftermarket ECU?
Old Nov 17, 2008 | 12:02 PM
L600MEY's Avatar
nope everything standard mate and the wheel brake is only 150 i would be happy if everything ran standard hes had 2 more in and the ran 235bhp-190whp ish
