Uneven Ride height
Old Aug 7, 2006 | 12:04 AM
EK9MAX's Avatar
Default Uneven Ride height
Ok, so I got some tein stech's installed tonight.
I get the car back and it's not even close to even. I know I'm supposed to let it settle a bit. But this is kinda ridiculous...
My front RIGHT is 1/2 " higher than the left
My back LEFT is a full 1" higher than the right
How can I check to see he put the right springs in the right place? I don't wanna go accusing him of wrong installation until I find out.
How important is loading the suspension before tightening everything? I told him about this when I dropped my car off. But he gave me the "ok whatever. it doesn't make a difference" look.
Old Aug 7, 2006 | 01:47 AM
SpitfireS's Avatar
Pre loading IS important and it DOES make a difference.
It may change not only the ride hight but also the handling.
Make sure its done right.
Old Aug 7, 2006 | 07:10 AM
EK9MAX's Avatar
Ok. So I should go do it myself?
Old Aug 7, 2006 | 07:22 AM
CoralDoc's Avatar
It is VERY important to properly pre-load the suspension before tightening it up. Not doing so can easily make a 1" difference in ride height even if the springs are in their correct location.
Old Aug 7, 2006 | 07:25 AM
CoralDoc's Avatar
Only if you know what you're doing. Otherwise, have someone with experience handle this. I'm not familiar with this model of Teins - I assume that it's not adjustable for ride height?
I suggest that you take the car to a good alignment shop and have them set it up. You'll need to do an alignment anyway.
Old Aug 7, 2006 | 08:07 AM
EK9MAX's Avatar
I am able to do this myself. I've done springs before. However Ijust didnt' have the time to do this myself. I guess I'm gonna have to make time to check it.....
Old Aug 7, 2006 | 08:36 AM
kitwetzler's Avatar
^ Tein paints part numbers on their springs. 1" is a LOT of difference.
Old Aug 7, 2006 | 08:37 AM
EK9MAX's Avatar
I drove the car this morning and it doesn't seem to be as big a gap... I'll have to messure again.
Old Aug 7, 2006 | 11:11 AM
EK9MAX's Avatar
The more I look at it.... It looks like the right side is an even drop. Where the left side the front is way lower than the rear......
Maybe he put front/back in wrong on my left side. does that make sense?
Old Aug 7, 2006 | 03:24 PM
Almostlude's Avatar
I'm curious, what is the proper way to pre-load a lowering spring? I just want to make sure that I did it correctly.
