Updated Banjo Bolts Sprayers?
Old May 4, 2016 | 10:37 AM
HawkS2K's Avatar
Default Updated Banjo Bolts Sprayers?
Hey all I have an AP1 and was going to do the Banjo Bolt upgrade. I have the new bolts but talking to dealer they are now showing an updated sprayer aswell in the catalog of parts? Should I do the sprayers aswell?
Thanks!
Old May 4, 2016 | 11:17 AM
hvAlfaWant_S2000's Avatar
I believe the banjo bolts are the sprayers themselves.
Old May 4, 2016 | 12:08 PM
cdelena's Avatar
No the bolt hold/feed the sprayers that are separate. Most of us that did the upgrade just used the sprayers on the car.
Old May 4, 2016 | 12:37 PM
Right! Sorry for spreading misinformation.
I know the new bolts have 4 holes to allow more oil to the sprayer. I just replaced the bolts too.
Here you go for reference:
Old May 4, 2016 | 01:38 PM
HawkS2K's Avatar
Thanks ya I have the new bolts. The dealer doesn't think they are different because they have same part #. I am just wondering if anyone knows anything about the new jets they are an updated part now.
Old May 4, 2016 | 03:32 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
How many miles are on the car? Do you plan to go FI in the future?
Old May 4, 2016 | 03:37 PM
HawkS2K's Avatar
27K No fi on this car. But want to do everything to keep it in good shape. I do like to run it up into Vtech when I get the chance and have some fun.
Old May 4, 2016 | 05:30 PM
Slowcrash_101's Avatar
You're frankly better off not touching anything, it's a bit of a delicate procedure. Not too long ago someone cracked their block trying to install the new ones. You have to be dead accurate with your torque, because if you're off the oil holes will not line up with the jets. It makes it even trickier because you don't have a straight shot at cylinder 1, and slightly on cylinder 2 unless you go through the trouble of removing the oil pump. I for one do not trust a torque wrench with a wobble/universal joint, any deviation from completely straight will change torque, and add in a poorly calibrated torque wrench and you can do some damage.
*It's only a problem if they were installed improperly from the factory on an AP1, because there's only one jet, and if the hole doesn't line up with the jet there's no oil jet, this is less likely to happen on the two jet, because you have a slightly higher chance of having things "line up".
Old May 4, 2016 | 11:23 PM
AP1Driver's Avatar
I've never heard it explained that way, but that makes perfect sense! Thx for the insight into a different thought line on their install (although I'll never upgrade mine because it's been fine for 100k miles under severe use )
Old May 5, 2016 | 04:10 AM
dedonderosa's Avatar
unless you plan on going forced induction or even doing NA track events with keeping high rpm for long periods of time, if you just plan on enjoying the car and driving it around on the streets and revving it out here and there you are fine leaving the factory banjo bolts in and will be fine.
