VAFC Harness Question
Old Aug 5, 2003 | 07:02 PM
Slows2k's Avatar
Default VAFC Harness Question
Has anyone used a VAFC plug in harness to install a Comptech ESM or the Vortech timing box? I have read both install manual wiring directions. But I am no fan of cutting the stock wiring harness or using displacement type splice connectors. Anyone got any ideas?
Old Aug 5, 2003 | 08:51 PM
Wesmaster's Avatar
No, but I used one to wire up to my eManage. It would work fine for what you're wanting to do, I believe.
Old Aug 5, 2003 | 09:21 PM
Slows2k's Avatar
Thanks Wesmaster
Old Aug 6, 2003 | 07:45 PM
CMiS2K's Avatar
the vafc harness is just an extension of the OEM harness, if the OEM harness is spliced per the directions of vortech(example) then the vafc and harness will work together just like the way they do when the car is NA.
or you could just splice the harness wires per instructions. Just find the correct pin per instructions on the right pin connector, ie 25 pin, 31 pin or 32 pin. why, cause the wires on the harness are all the same color except the corresponding wires that are spliced into the vafc.
I will be plugging my vafc and harness back in tonight to see if this is true or not.
the only concern I have is, will the vafc see boost? if it does then it doesn't work.
Old Aug 6, 2003 | 10:14 PM
CMiS2K's Avatar
DON"T CUT IT!!!
just cut/splice/tap the oem wiring harness just like the vortech manual says to do. The harness will plug N play just as it is designed.
if you do decided to splice the harness you will still have to splice the oem harness MAP 17 wire, this will still have to be done the way the vortech manual says. Reason? to keep the vafc from seeing boost, if the vafc see's boost then the ECU will also. The map controller needs to be spliced in on the oem harness, so that boost pressure is blocked before hitting the vafc via the harness.
I hope this helps. I just got back from running my car for an hour and no CEL and NO boost was seen by the VAFC or ECU. All I did was plug the vafc + harness back in the way it was designed to begin with!
Old Aug 7, 2003 | 03:51 PM
fperra's Avatar
Who sells the harness?
Old Aug 7, 2003 | 06:46 PM
CMiS2K's Avatar
4IGS2000
Old Aug 8, 2003 | 03:20 AM
Venomous S's Avatar
[QUOTE]Originally posted by Slows2k
[B]Has anyone used a VAFC plug
Old Aug 8, 2003 | 03:21 AM
Venomous S's Avatar
[QUOTE]Originally posted by HardtuTame
[B]
save yourself a headache and frustration.
Old Dec 23, 2005 | 12:00 AM
Aznous's Avatar
Does the S2k VAFC 2 harness work w/ 0BD1,0BD2A OR 0BD2B? Theres 3 different type of Plug n play harnesses for the S2k's VAFC2 dont know which one to get?
t1rs2k02
Sep 3, 2009 01:03 PM
alan_s2ki
Jun 9, 2009 08:18 PM
blackfx35
Aug 16, 2006 09:47 AM
S2K_408
Mar 18, 2006 12:24 PM
mustangkiller01
Jun 12, 2004 07:20 AM
