Valve adjustment
Old Jan 28, 2015 | 09:56 AM
dlpowered89's Avatar
Default Valve adjustment
Hey guys,
I own a 2008 S2000 which I bought from a Honda dealership as certified used. I bought the car with 55k miles and I was wondering if valve adjustment is included as their refurbishing process. It's sitting at 69k now and I am considering to do the work.
Thanks,
Don
Old Jan 28, 2015 | 10:13 AM
Reckon's Avatar
They do not do a VA as one is not spec'ed in the manual to be done till about 105k miles on it. CPO means they redid the oil and gave it a multi-point inspection to make sure everything was in working order. They still go by the book:
http://techinfo.honda.com/rjanisis/p...u/S20505OM.pdf
Old Jan 28, 2015 | 10:58 AM
Thanks for the reply. 105k mi sounds like awful amount of miles until they require adjustment. What is S2kis recommendation on this work?
Old Jan 28, 2015 | 11:21 AM
wineboy's Avatar
I have an 07 and do a valve adjustment every 50 - 75k miles. It's about $200 a $250 if you have it done by Honda
Old Jan 28, 2015 | 12:06 PM
I wonder if valve adj is something that can be done at home.
Old Jan 28, 2015 | 12:29 PM
HarryD's Avatar
There is an important sticky at the top of this forum for valve adjustments that applies to your model year:
https://www.s2ki.com/s2000/topic/106...ners-dbw-cars/
Old Jan 28, 2015 | 12:37 PM
devildust's Avatar
its not very hard to do, just takes practice and the right tools.
Old Jan 28, 2015 | 12:49 PM
PixelJunkie94's Avatar
I would recommend a valve adjustment for sure! Some newer model cars have an issue with the exhaust valves burning up. It couldn't hurt and its not too difficult to do by yourself if you have a decent knowledge of how valve trains work.
Old Jan 28, 2015 | 12:56 PM
Yeah. I am fairly competent when it comes to working on a car, but the description says I should feel the right amount of "drag." This is what worries me since it is the valve we are talking about here and I can potentially mess it up. :/
Old Jan 28, 2015 | 01:07 PM
Slowcrash_101's Avatar
Put your fingers on something flat, now without pressing down(just resting with the weight of your arm), move your fingers back and forth across the flat surface, that's the kind of drag you're looking for from the feeler gauge.
