valve adjustment
Old Jul 25, 2019 | 08:33 PM
phil81's Avatar
Default valve adjustment
I just bought a 2003 S2000 and am doing some first time maintenance. When lining up the timing marks for TDC, the #1 cam lobes point in, not out at 11 and 2. All other marks are correct with cam marks facing each other at 9 and 3. and center gear marks are at opposite ends of the gear are right above the top of the head and the crank pulley is on the white mark. I can figure out how to do the valve adjustment doing the cylinders with cam lobes that are a 11 and 2 with free play that allows the feeler gauge to be inserted. What I can't figure out is how can the engine run as well as it does. Wouldn't the ECU know that things are off ? How would it get this way? Last owner is a friend who's had the car for 10 years and said he just lived with it because the car ran so well.
Thanks
Old Jul 26, 2019 | 01:38 AM
flanders's Avatar
Is your cam gears switched up between intake and exhaust?
There is a groove on the face of the exhaust cam gear and the intake one is smooth, that is the easiest way to tell the difference.
Old Jul 26, 2019 | 06:06 AM
s2000maniac's Avatar
As long as you can wiggle the adjustment nut then it should be fine to adjust the valve.
subwayasian
Jul 13, 2014 10:22 PM
Boss-S2K
Jun 4, 2013 05:14 PM
SpitfireS
Feb 1, 2013 02:34 PM
StockSH
Aug 15, 2005 10:19 AM
stefluva
Sep 7, 2004 08:54 PM
