Valve Adjustment Keeps Tightening By Itself?
Old Mar 8, 2021 | 02:18 PM
Muugens's Avatar
Default Valve Adjustment Keeps Tightening By Itself?
So here's a weird problem. I have a valve that keeps getting too tight and tripping a missfire code. Specifically the rear intake valve on Cyl #3. I pull the valve cover and set it back to spec and everything is fine on the street until I do a track day and beat on the car a bit. Come home and magically it's misfiring again and that one valve is way too tight -so tight that not even my smallest feeler gauge fits.
No visible damage to the adjuster, the stem of the valve seems to be at the same height as the others. Clearance on the others remains within spec, and the head was rebuilt last year. Upgraded to AP2 retainers at the same time. Those also appear to be fine. Leak down on that cylinder is good (albeit after the valve is returned to it's correct spec). The clearance just gets tighter because it feels like it. Go figure, any thoughts?
Old Mar 8, 2021 | 04:28 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Is the cylinder head all oem?
Old Mar 8, 2021 | 04:33 PM
zeroptzero's Avatar
Does the locknut torque down properly - 14 ft lbs ? , just wondering if it could be stripped.
Old Mar 9, 2021 | 04:36 AM
Muugens's Avatar
Yes it is. Rebuilt recently, but with all oem stuff.
Old Mar 9, 2021 | 04:49 AM
Billman250's Avatar
Top Answer: 1
Problem with the build.
The valve stem or seat is moving upwards. Bad guide, non-oem valve, seat not seated
Old Mar 9, 2021 | 02:56 PM
windhund116's Avatar
I've seen this in BMW engines with bad or improperly fitted seats.
c_me_go
Jun 25, 2016 10:56 AM
Tdoolin18
Jun 23, 2016 02:04 PM
Roshton
Feb 23, 2016 03:38 AM
rasulrasulinho
Jun 24, 2015 06:24 PM
