Valve Adjustment needed?
You can request that they note the before and after valve clearances, but even then they could just make up numbers. The only way to truly know that they do the job is to stand there and watch. I would recommend asking friends and relatives if they know of any good mechanics. Although many people assume the dealership is the most knowledgeable source for work, this is often untrue. They are generally just trying to squeeze every buck out of you that they can with minimal work and will often cut corners or rush the job. An independent mechanic knows that his livelihood depends on his reputation, and he doesn't have as much overhead cost so you have a better chance of getting quality work at a decent price.
forget this job if you have a weak or problematic back. forget the sequence of rotating the crank, just make sure the cam lobes of the valves you are adjusting are pointing to 10 and 2 (basically so there is no pressure on the valves - everything will become more clear once your in there looking at everything.
Not really. You use feeler gauges to measure it.
I agree, I would only get a valve adjustment from a known trusted source...otherwise I would say forget it, leave the car as-is and dont subject your car to being worse off. Too many variables, mechanic thinks good enough, doesnt let it cool down,etc.
Update: Adjusted the valves today. The intake valves on cyl. 1 & 2 were tight, while 3 & 4 were good. All of the exhaust valves needed adjustment, mostly too tight, with one or two that were just a hair loose.
This is on a motor with 24,000 miles.
-Connor
-Connor
It seems strange to me how loose the spec is four our valve lash. Im used to old BVTEC motors where its like .005-.006 than the looser .008 on our F20s. Also, historically, I am used to the lash loosening up over time, not tightening. Anyone know why we have such a big gap or why these have seemed to be tightening over time on our motors?
Im at 114k miles with no valve adjustment yet. hope all is well. gonna order a valve cover gasket kit and feeler gauges from advance auto. im tech savvy and the pdf shows enouph info to get the job done well.
anyone find issues with the spark plug gaskets?
