valve clearance adjustments..
Old Mar 13, 2008 | 10:04 PM
pinoyk20's Avatar
Default valve clearance adjustments..
hi guys!! good day!! its time for me to have my valve clearance adjustments . whats are the specs on the adjustments??? and whats would be the best clearance for the intake and exhaust?? thanks thanks!!! im doing it cold . thanks so much guys!!! i really need your help on this one guys! thanks so much!
Old Mar 14, 2008 | 04:07 AM
pinoyk20's Avatar
anyone pls?? im in need of the specs of the valveclearance adjustments. pls
Old Mar 14, 2008 | 04:09 AM
MIAMI S-2000's Avatar
The Manual gives these specs:
Intake .008-.010
Exhaust .010-.011
Cold, you should use new feeler gauges because sometimes old ones have kinks in them, also there is a tool you can buy that is like a open ended socket that will let you stick a screw driver in the top of it so you can manipulate the adjustment better.
Old Mar 14, 2008 | 04:22 AM
one_slows2k's Avatar
I have that tool! bought it from amazon, works great, very cheap as well. and by the way, I would suggest using one of those bending torque wrenches.. I used a click style method one time and I kept wondering why is this thing not clicking... one thing you want to avoid is to overtighten those nuts. ask me how i know. lol
Old Mar 14, 2008 | 07:27 AM
OK, I'm game, how do you know?
Old Mar 14, 2008 | 07:34 AM
attack666's Avatar
any DIY thread?
Old Mar 14, 2008 | 10:35 AM
Do a search!
Old Mar 15, 2008 | 05:35 AM
turbo pup's Avatar
Is this the tool that you guys are talking about? Tool
Also, are the lock nuts 10 or 12MM? Would like to order the tool so I'm ready for my upcoming adjustment
Old Mar 15, 2008 | 08:00 AM
chuhsi's Avatar
i think the specs are also listed on the underside of the hood on the white sticker
Old Mar 15, 2008 | 07:49 PM
pinoyk20's Avatar
Intake .008-.010
Exhaust .010-.011
than so much miami s2000!!! but which spec should i go for cause its .008-010 for intake and .010-.011 for exhaust. is this in mm????or i forgot the other size unit they are using i know there is mm and the other one is............ thanks so much for your help sir!!
