valve noise... possible tap
Old Nov 8, 2008 | 12:47 PM
jonnys2k01's Avatar
Default valve noise... possible tap
ok so i dont have a vid or ne thing.. but this is exactly wat my s2k sounds like http://www.youtube.com/watch?v=fBuMdkEmtLw
i just did the valve lash.. and it still makes that noise... normal?? concerns>??? advice...
Old Nov 8, 2008 | 12:57 PM
jonnys2k01's Avatar
if i need to rebuild... im going with brian crower dual valve springs and retainers...
but what kinda valves should i go wtih.... supertech?? brian crower... ???
Old Nov 9, 2008 | 04:59 AM
jonnys2k01's Avatar
so yea... after i did the valve lash.. damn ticking is louderrrr grrrrr.... and now engine is running rough.... grrrrr at 1st i did min specs... then i re did it to in between the specs... 11 and 9... how much drag should it have??? tight to where u cant move it? or so u can hardly slide it...
Old Nov 10, 2008 | 07:17 AM
ROTFLMAO's Avatar
Mine sounds like that too.
Old Nov 10, 2008 | 03:35 PM
jonnys2k01's Avatar
should i be concerned?
Old Nov 10, 2008 | 03:36 PM
jonnys2k01's Avatar
either rebuild head... or buy mugen hard top... by spring
Old Nov 10, 2008 | 04:36 PM
jyeung528's Avatar
have someone else do your valve adjustment.
Old Nov 10, 2008 | 05:36 PM
jonnys2k01's Avatar
i did it 3 times
Old Nov 11, 2008 | 09:26 AM
jyeung528's Avatar
maybe you're not doing it correctly.
Old Nov 11, 2008 | 09:47 AM
armthehomeless's Avatar
I went with the crower valves , there stainless steel instead of black nitrate, black nitrate valves have supposed advantages, retain less heat, smooter better flow. but there are no real numbers to support this.
If you got the extra cash, p&p and go oversized. youll need new intake seats too if you go oversized.
