Which valve retainers do I order?
Recently picked up a 2002 S2k with 64000 miles. Everyone recommends having the valve retainers replaced with ap2 retainers. Which should I order (brand etc...) there seem to be a lot of different types out there and I'm not sure which is correct???
Thanks!
Thanks!
^ this. sort of. it has been argued that ap2 retainers on ap1 exhaust valves isn't an ideal situation. you should mix and match ap1 exhaust retainers/keepers with ap2 intake retainers/keepers. I know hardtop guy will mix and match a set for you if you specify in the "special instructions" section of the checkout.
14620-PCX-010 1 ARM ASSY., ROCKER JPN
$ 286.43 $ 209.67
14711-PCX-000 2 VALVE, IN. (YELLOW) (NIPPON HATSUJO) JPN
$ 20.27 $ 14.84
14721-PCX-000 3 VALVE, EX. (BLUE) (NIPPON HATSUJO) JPN
$ 33.77 $ 24.72
14744-PCX-014 4 SCREW, TAPPET ADJUSTING JPN
16
$ 3.28 $ 2.40
14761-PZX-A01 5 SPRING, IN. VALVE (WHITE) (NIPPON HATSUJO) JPN
$ 8.87 $ 6.49
14762-PZX-A01 6 SPRING, EX. VALVE (ORANGE) (NIPPON HATSUJO) JPN
$ 8.87 $ 6.49
14765-PRB-A01 7 RETAINER, VALVE SPRING JPN
16
$ 3.20 $ 2.34
14775-PCX-000 8 SEAT, VALVE SPRING JPN
16
$ 2.98 $ 2.00
14781-PCX-004 9 COTTER, VALVE JPN
32
$ 2.57 $ 1.88
14820-PCX-003 10 MOTION, LOST JPN
$ 9.70 $ 7.10
90206-PT0-004 11 NUT, TAPPET ADJUSTING JPN
16
$ 1.87 $ 1.37
I replaced all my retainers with AP2 retainers. None of my AP1 retainers had cracks so I could have left it alone and perhaps should have to save $ but it was peace of mind for me. Had a valve adjustment done at the same time and the car runs a little better now.
