Valve Spring Compressor Tool
Old Nov 9, 2004 | 09:47 AM
cjb80's Avatar
Default Valve Spring Compressor Tool
I need to take apart my head and I was curious if anyone else has done this, and if so, what valve spring compressor tool did you use?
Thanks!
Chris
Old Nov 9, 2004 | 12:29 PM
beroznikmal's Avatar
Snapon sells one... let me try and find the link......
Old Nov 9, 2004 | 12:32 PM
http://buy1.snapon.com/catalog/pro.asp?too...re=snapon-store
Hope this helps
Old Nov 9, 2004 | 12:38 PM
cjb80's Avatar
I recall that there were some special requirements for the valve spring compressor because it was so tight. I remember that the Snap on one worked, however. Should I get this one: #YA3271 ??
Thanks!
Chris
Old Nov 9, 2004 | 02:30 PM
Slows2k's Avatar
I Just had my cams out today to check the retainers. I've got a MAC tools spring compressor that looks just like the Snap-on YA3271. It looks like it would be tight, but should work.
Old Nov 9, 2004 | 03:20 PM
biker1's Avatar
Certainly the Snap-on YA9140 works, you have to alter the bridge where it mounts on the head a few times to get to all the valves but its no big deal.
The kit is robust and it did the job that I needed it for fine.
Old Nov 9, 2004 | 03:28 PM
yogi's Avatar
You only need a spring compressor to put the springs back on. To take them off, just put a piece of cloth over the valve/retainer, put a large size socket over it, and tap with a mallet, valve will fall right out. Don't do this with the head still on the block
Old Nov 9, 2004 | 03:32 PM
Slows2k's Avatar
That will get em out Yogi. Just watch for the flying keepers.
Old Nov 9, 2004 | 03:38 PM
yogi's Avatar
That's what the cloth is for
Old Nov 9, 2004 | 03:44 PM
Slows2k's Avatar
With my luck I'd send a keeper 20 feet across the shop were it will refuse to be found.
