Valve Spring Replacement without head removal
Old Nov 23, 2003 | 11:48 AM
Turtle's Avatar
Default Valve Spring Replacement without head removal
I'm going to be replacing the valve springs on my car soon, and wish to do this without removing the head. The air hookup to the cylinder to stop the valves dropping is no problem, however there doesn't seem to be any firm info on which tools fit for compressing the valve spring from the top. I know bridge style compressors work for this approach, but I'm concerned that reach may be a problem given the head design of the F20C.
There used to be a 'how to' on installing cams, that presumably had the info there. (URL was, http://www.nes2ko.com/how_tos/cams.htm, but the page isn't there anymore).
A search didn't produce anything fully conclusive. If you've done this job, and know a tool that fits I'd appreciate knowing what you used. It'll save me a lot of time and running around, should my existing tools not be suitable.
-Brian.
Old Nov 23, 2003 | 07:15 PM
Squeezer's Avatar
The helm manual says to use honda special tools:
1. VALVE SPRING COMPRESSOR ATTACHMENT, 07757-PJ10100
2. VALVE SPRING COMPRESSOR 07757 - 0010000
but it looks like you have to take off the head to use them. maybe you can use #1 without #2? dunno...see if summit racing has anything for valve springs on a honda civic or acura integra. its probably the same for the s2000.
Old Nov 23, 2003 | 11:44 PM
vapors2k's Avatar
snap on sells the specific valve spring compressor tool that will fit the deep and tight space in the head. You can do this with the head on the car. Cost of the tool is roughly $200.00.
-ardy
Old Nov 24, 2003 | 12:31 AM
Turtle's Avatar
Thanks - nice to have another source of confirmation for the SnapOn.
-Brian.
Old Nov 24, 2003 | 10:12 AM
RStoR's Avatar
Snap-On unit works great, but it does take two people to perform install with it. Also invest in a nice set of long tweezers if you don't have any already.
Old Nov 26, 2003 | 04:10 PM
Venomous S's Avatar
[QUOTE]Originally posted by Squeezer
Old Nov 26, 2003 | 04:14 PM
beroznikmal's Avatar
http://buy1.snapon.com/catalog/pro_det.asp...ore&dir=catalog
check out the link.....
I think Wicky installed his TODA cams by himself..... Ask him what he used.....
Beroz
Old Nov 21, 2007 | 04:22 PM
Kyushin's Avatar
Banned
So springs, seats and guides can be replaced without removing the head?
Old Nov 21, 2007 | 04:32 PM
mikegarrison's Avatar
Yes, but there's a big learning curve.
Old Nov 21, 2007 | 05:23 PM
RED MX5's Avatar
Even with experience, a mistake can still be costly. I tend to think of this as a relatively easy task now, but I have bent a valve while doing a cam swap, by making a mistake that I really shouldn't have made. First time, it's a lot less stressful and risky if you can get some help from someone who's done it before.
