Valve Tap when car is started
Old Jun 16, 2008 | 07:41 AM
Jamikee's Avatar
Default Valve Tap when car is started
I recently purchased a 2003 S2000 with 89,000 miles. When starting the car it sounds like the valves are making noise but then stop after a few seconds of idling. I was wondering what causes that noise and how it can be fixed. I have recently just got an oil change and thought it would solve the problem but it hasn't.
I figured if the valves had to be adjusted that it would make noise all the time. I also thought that maybe its the fuel pump that when the car is sitting the oil settles then when started its not forcing enough oil through which is causing the noise. If anyone has any information please let me know thanks.
Old Jun 16, 2008 | 07:55 AM
2poor2mod's Avatar
sounds like the Timing Chain Tensioner
2poor2mod's Avatar
https://www.s2ki.com/forums/index.php?showtopic=320897
Old Jun 17, 2008 | 05:11 AM
Jamikee's Avatar
How easy is it to adjust the tensioner or does it have to be replaced?
Old Jun 17, 2008 | 06:52 AM
Jamikee's Avatar
does anybody have step by step instructions on doing such a job?
Old Jun 17, 2008 | 07:22 AM
kalibo's Avatar
If you search you will find. Check the How to's on the main under the hood page. It's very easy. It's located underneath the vtec solenoid.
Old Jun 18, 2008 | 05:35 AM
rvenom's Avatar
https://www.s2ki.com/forums/index.ph...c=320897&st=25
its all here
Old Jul 22, 2008 | 06:26 AM
Jamikee's Avatar
That was the answer the cam chain tensioner. Thanks so much for your guys help, easy fix
Old Jul 22, 2008 | 07:11 AM
TRBOKEV's Avatar
if your running Mobil 1 I suggest you get rid of it ASAP with a good oil like Redline or Amsoil.
I had LOTS of valve train noise, even replaced the tensioner and it (the noises) came back after a month. Switched my oil to Redline and ALL of my funny noises have disappeared.
Old Jul 22, 2008 | 11:17 AM
slipstream444's Avatar
It's possible that's not the problem. If it quits within a few seconds after starting it's normal. Every car will make a little noise until there's enough oil present to dampen it. Properly adjusted valve lash will reduce this as well.
However, if the car makes a very noticable noise - as loud as a diesel, for much longer than you're suggesting - then it could be the TCT.
