valves?
Old May 10, 2006 | 05:51 AM
roadents2k's Avatar
Default valves?
I have a ticking comming from the motor I figured it needed a valve adj. so I took it to the shop and they mdae the adj. they also said they think I bent a valve. I have missed 2nd gear a few times cound this bend a valve, or did I throw the timing off. I ran the car open header one time would a burnt valve be ticking?
Old May 10, 2006 | 06:43 AM
xviper's Avatar
"Missing" 2nd won't do anything. Going into 2nd when you didn't mean to, might just bend a valve or 2 or 3 or 4.
Old May 10, 2006 | 07:39 AM
Sideways's Avatar
Running it to extreme temperatures with an open header then having it cool too quickly with an Icy wind could theoretically cause exhaust valve warpage. In reality I doubt it.
Why do they say you bent a valve? Is it running poorly, missing, poor compression or failed leakdown test? More info would be helpful.
Old May 10, 2006 | 09:21 AM
roadents2k's Avatar
sometimes it sounds as if it has a cam
Old May 10, 2006 | 10:38 AM
xviper's Avatar
It does have a cam. In fact, it has two cams (shafts, that is).
Old May 10, 2006 | 11:11 AM
Sideways's Avatar
[QUOTE=xviper,May 10 2006, 11:38 AM]
Old May 10, 2006 | 11:18 AM
xviper's Avatar
Originally Posted by Sideways,May 10 2006, 12:11 PM
Dave,
In his statement "sound as if it has a cam" is a colloquialism referring to lope at idle that is very pronounced like the old Corvette Duntoff cams and infers a high performance cam.
Thanks for the explanation. This is not a term I'm familiar with. Now, "lopey idle", I can relate to.
Old May 10, 2006 | 08:10 PM
chris_barry's Avatar
Get a leakdown test done on the motor. If the valve is bent it will leak a truckload into the exhaust or inlet.
Old May 11, 2006 | 05:02 AM
roadents2k's Avatar
would the valve be causing the car to lope. could it be a broke valve spring
Old May 11, 2006 | 06:16 AM
Squeezer's Avatar
i think you are hearing the fuel injectors pulse
