VErsion 2 Toda cams
Old Jul 15, 2003 | 07:15 PM
  #191
Greenlight's Avatar
F20C Spec A2 295 Intake
Hi Cam IO BTDC 27.5
IC ABDC 47.5
Intake CL 100
Duration @ 1mm 255
Valve Lift 13mm Advertised (12.7mm Actual)
Primary Cam
IO BTDC -15
IC ABDC 30
Intake CL 112.5
Duration @ 1mm 195
Lift Advertised 8.0 mm
F20C Spec A2 290 Exhaust
Hi Cam EO BBDC 47.5
EC ATDC 22.5
Ex CL 102.5
Duration @ 1mm 250
Valve Lift Advertised 12.0 mm (Actual 11.65 mm)
Primary Cam EO BBDC 30
EC ATDC -20
Ex CL 115
Duration @ 1mm 190
Valve Lift Advertised 8.0 mm
BTW, there may be another outlet to purchase s2k camshafts.
Refer to: https://www.s2ki.com/forums/showthread.php?...threadid=135237 for additional information.
Hope this helps!!!
Old Jul 16, 2003 | 05:55 AM
  #192
Gernby's Avatar
Former Sponsor
Are the primary and secondary cam lobes the same? The OEM cams have staggered lift on the primary and secondary lobes.
Old Jul 16, 2003 | 06:04 AM
  #193
beroznikmal's Avatar
gernby,
The primary and secondary cam lobes are not the same.... they are staggered also... the only difference is the cams lobes are bigger......
slick rick,
Please refer to the last post on the first page of this posting.....I had turbo_pwr post the specs for me.....
Beroz
Old Jul 22, 2003 | 06:05 AM
  #194
mxt_77's Avatar
ttt
Just out of curiosity, have we seen the before/after dyno charts for a properly tuned set of these Toda Stage 2 cams?
Old Jul 22, 2003 | 06:10 AM
  #195
Sorry peeps,
The place that dynos my car is moving the dyno to another slot........... it will take at least a week for them to reinstall the damn thing..............
I have recently changed out the mugen setup with the TODA setup and have noticed a different......butt tells everything is good......
There is another place that offers dyno services around my area but to stay consistent with previous measurements I would be better off waiting for the dyno to be reinstalled..........
waiting and anticipation is a Bi@#h isn't it.........
Beroz
Old Jul 22, 2003 | 06:12 AM
  #196
Gernby's Avatar
Former Sponsor
What "mugen setup" did you have that was replaced with Toda?
Old Jul 22, 2003 | 06:16 AM
  #197
Well I basically replaced the Mugen header with the TODA header and replaced the exhaust with a more 'freeflowing exahust'
Beroz
Old Jul 22, 2003 | 06:17 AM
  #198
mxt_77's Avatar
Yeah, it is!
Old Jul 24, 2003 | 05:48 AM
  #199
S2K@PR's Avatar
Update?
Old Jul 24, 2003 | 09:25 AM
  #200
wicky's Avatar
Okay. I've had mine in for about a week now. I have not dyno'd yet as it is a bit difficult to coordinate time off from work right now (very busy these days). But here's my first impressions:
Of course, mid-range is much stronger. The power past 3k ramps up much quicker. I no longer feel as though the power plateaus between 4-5k. 3k-6k is very strong. At 6k VTEC kicks on like a switch and pulls hard. I'm not sure about top end power. After 7k it is either less of a power gain or no power gain. It may just be the mid is so strong I don't notice the top, but the dyno will tell the real story (this is also where torque falls off so it makes sense to not "feel it" as much). Below 3k has been a little boggy which I would expect with aggressive cams, esp. on this motor. But the last day or so it hasn't been so bad, so I think the ECU might be figuring these cams out.
Side note about tuning: UL suggested that my car seemed a little rich last time I dyno'd and I would expect the situation to be the same or worse with these cams. I have no computer to tune with, I am expecting to install an EMS in about a month. At any rate tuning should help alot, and to me the car bogs and pops as if it was a tad rich. Also my valves are very loud when the motor is warm and has been driven so I think the adjustment needs to be double checked.
Beroz - have you been driving yours much? I have a couple hundred miles on mine now. I'm curious what your impressions and opinions of what I've felt are...
