Vibration under acceleration... :(
Old Mar 6, 2008 | 01:43 PM
TypeOne's Avatar
Default Vibration under acceleration... :(
Hey guys, I'm a new S2000 owner and I've got a weird vibration under acceleration only.
Car info:
2001 SSM S2000
128k miles
Other than the car obviously having an aftermarket clutch, it's completely stock. The car will be getting a 4 wheel alignment soon.
Does not vibrate when you turn, brake or in neutral. It also does not shake or vibrate while free revving.
I have searched around the forums and I read something about CV joints going bad?
Any insight would be greatly appreciated!
-David
Old Mar 6, 2008 | 03:48 PM
2poor2mod's Avatar
is happening at all speeds or only on takeoff?
Old Mar 6, 2008 | 04:29 PM
DR. FEINSTONE's Avatar
get the engine mounts and transmission, differential mounts replace. Your car have over 100,000 miles. These items need replacement unless you already done it. Have it check out, I bet they have some cracks already.
Old Mar 6, 2008 | 06:52 PM
TypeOne's Avatar
It does it at all speeds, if I drive 10mph and accelerate to 40 it does it just the same if you go from 60 to 90.
I will stick it on the lift tomorrow and inspect the mounts. Are they notorious for this kind of wear? The car is in very good condition...
Old Mar 7, 2008 | 04:11 AM
AP1FTW00's Avatar
It is still reccomended to get them chagned
Old Mar 7, 2008 | 04:16 AM
silvers2k01's Avatar
search inner cv joint swap and thats probably your solution
Old Mar 7, 2008 | 08:46 AM
jyeung528's Avatar
i'm going with the mounts...
the cv joints would vibrate in turns as well...
Old Mar 7, 2008 | 08:48 AM
Voodoo_S2K's Avatar
He is referring to the rear inner CV joints. It's a pretty common problem.
Old Mar 7, 2008 | 09:17 AM
jyeung528's Avatar
right...
but the rear inner cv joints would still vibrate during turns...yes?
Old Mar 7, 2008 | 09:56 AM
Voodoo_S2K's Avatar
Not necesarilly.
