(video) high pitched noise
Old Mar 30, 2011 | 06:04 PM
ConanO'Brien's Avatar
Default (video) high pitched noise
wtf could be causing such a high pitched noise??? suspension component? i am taking the car to honda on friday and am going to be pretty pissed if i spend 150 dollars for a "diagnosis" and they can't even find the noise. i've been pushing around and cannot replicate it. turn the volume up as the sound is not super prominent. thanks...
http://www.youtube.com/watch?v=rVgP79VUCwI
Old Mar 30, 2011 | 06:25 PM
s2cho's Avatar
it could be your brakes, or the rubber bushings to the suspension
but if its coming from the rear it could be your dif going bad/blown
or your wheel bearing is going bad/is bad
but i never really heard that kinda sound before.
do you know where it is coming from?
cause then it will be pretty easy to identify then
Old Mar 30, 2011 | 06:43 PM
Carbon Blue's Avatar
soft top frame rails??
Old Mar 30, 2011 | 06:55 PM
i should clarify. it happens with the top up OR down. sounds like it is coming from inside the front dash. : /
Old Mar 30, 2011 | 06:59 PM
s2cho's Avatar
does it happen with ac/heater on?
Old Mar 30, 2011 | 07:00 PM
on and off. doesn't matter
Old Mar 31, 2011 | 11:08 AM
giving this one more bump before i go blow money at the honda dealership tomorrow for them to figure it out.
Old Mar 31, 2011 | 11:24 AM
CU03BLKS2K's Avatar
Do you still have the stock suspension in?
Old Mar 31, 2011 | 12:41 PM
yeppers...got new brake pads put in a few weeks ago but that was only a couple days after i purchased the car. could be related? def. sounds like it's higher up than the brakes though.
Old Mar 31, 2011 | 01:36 PM
CU03BLKS2K's Avatar
I honestly don't know man. I'll occasionally hear something similar when I hit a sharp bump or something, but nothing near as bad as yours. I really never noticed it at all until I changed my suspension and lowered the car, but it's so rare that I don't really worry about it. That is why I asked if you have the stock suspension though. Wish I could help. GL
