VSA ABS CEL
Old Jan 21, 2016 | 11:11 AM
rsousa45's Avatar
Default VSA ABS CEL
Hi, my 07 S2000 when driving at above 70 mph the VSA and ABS light turns on. When I turn off the car and wait a few minutes when I turn it back on it's off. It always turns on when almost reaching 80mph... Also the car has a CEL, turns out to be a faulty O2 sensor. I brought it to the dealership I bought it from to have it fixed. They said they installed a new engine computer because the old one wasn't reading the new O2 sensor installed. Also a new catalyst converter was installed. So I took it today to get my inspection sticker and the guy says that it still has the same code ! Then I am driving back home and the CEL light comes back on again.
Error Codes Read
P2271 Secondary H02S (Sensor 2) Circuit Signal Stuck Rich
P2A00 Air/Fuel Ratio Sensor 1 Circuit Range/ Performance Problem
P1172 Air/Fuel Ratio Sensor 1 Circuit out of Range High
I was told I need a new a/f sensor.
Old Jan 22, 2016 | 09:36 AM
Super Nintendo Chalmers's Avatar
New cat and ECU and the problem still isn't fixed? Hope you have a warranty.
Old Mar 19, 2018 | 04:28 AM
rsousa45's Avatar
Originally Posted by isthisusernameavailable
Can you say how your problem was eventually resolved?
Also have an '07, and received two of the same codes P2271, AND P1172. Interestingly, the p2271 (stuck rich) was preceeded by a P0171 (system running too lean) a few drives prior.
hi just read your message, I still have the Vsa light when i drive over 80 mph, didn’t fix this problem yet. The dealership said the o2 sensors are very sensitive in the s2000. They solved the problem with new o2 sensors. Cel just came on again 1 year later. Appears to be a P0139. Bought a sensor from rockauto.com still didn’t install it, waiting for the weather to get warmer.
-Matt
Mar 4, 2017 09:15 AM
mister_s
Feb 1, 2016 03:35 PM
abnormals2k
Nov 28, 2011 05:38 AM
s2tofu
17
Mar 22, 2011 03:49 PM
