Vtec engagement issue
Old Oct 30, 2017 | 02:47 PM
TvoS2K's Avatar
Default Vtec engagement issue
So recently I have not been able to hit vtec or any rpm over 6k. Now what I mean by this is 1k-5.5k the car acts and drives like it should but anything over that it breaks up like there is a fuel related issue. Now this only happens in vtec. I would like to think its just the vtec solenoid since thats where the problem starts. There are only bolt-ons on the car. 168k in miles
Old Oct 30, 2017 | 07:57 PM
S_DosMil's Avatar
I am having the exact same issue. When did this start? Any mishaps you can think of? Mine is currently at the shop. Mechanical and all electrical have checked out.as well as oil pressure. Still chasing down any issues.
Old Oct 30, 2017 | 08:03 PM
windhund116's Avatar
Fuel injectors?
Old Oct 30, 2017 | 09:55 PM
starchland's Avatar
Hate to be alarmist but mine was oil pressure related. Low oil pressure meant no vtec engaging and then the a/f goes super rich and bogs down
Old Oct 31, 2017 | 03:40 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Chances of the VTEC valve malfunctioning are extremely slim.
Old Oct 31, 2017 | 05:24 AM
TvoS2K's Avatar
Its been happening for the past couple of weeks i drive the car but i stay a away from vtech and everything is fine. I can rev the car to 9k and everything is as it should. tomorrow im going to do a little teardown to see if i can see anything out of order and check my vtec solenoid.
Old Oct 31, 2017 | 05:47 AM
TvoS2K's Avatar
Originally Posted by windhund116
Fuel injectors?
I do not believe it is the fuel injectors because it would have been doing the same thing if i were to redline while not under a load
Old Oct 31, 2017 | 09:15 AM
S_DosMil's Avatar
So we have the exact same issue. Check vtec solenoid screen. The shop has checked oil pressure in three locations and all is good. It free revs to 9k as well just won’t go past 6k underload.
Old Oct 31, 2017 | 12:07 PM
TvoS2K's Avatar
have you checked yours? If so what were your findings
Old Oct 31, 2017 | 04:10 PM
S_DosMil's Avatar
my gaskets are both new top and side. Not my issue. So far everything is checking out. Have you checked to see if your ecu is firm and in place? I have heard they can ground out not sure how true it is but also not my issue.
