VTEC kick isnt brutal...
Old Oct 20, 2006 | 07:36 PM
villeneuve's Avatar
Default VTEC kick isnt brutal...
Hello evryone , quick description of my problem.
-Idle , i lose sometime like 100 rpm so the car shake a bit.
-The VTEC isnt "brutal" at all , its really soft when the VTEC kick (always).
-Sometime in full acceleration especially in VTEC range, the rpm stall around 7k(not all the times) then it comeback normal , stall at 8000rpm .. etc ..
-The performance of the engine are not too good definetly even a stock Prelude beat me..well almost equal.
Its an 00 , whit CAI whit 70 000kms, they changed IAC valve (280$) last week ,problem not solved.
I saw description of some other members whit similar problem it look like its the MAP SENSOR.
What you think ?
Thanks.
Old Oct 20, 2006 | 09:50 PM
FISH22's Avatar
dont quote me on this, but before i would of had that iac valve replaced, i would have done the good ol map whack. or maybe even a map sensor replacement. about 60 bucks at hardtopguy. tap the map sensor lightly with the handle of a screw driver, but not too hard.
Old Oct 20, 2006 | 10:03 PM
Ek9's Avatar
Ek9
Banned
I'm not sure I trust your measuring stick.
Straight line it's not that fast of a car. Particularly the 00-03's. It's not a light car and it doesn't have huge amounts of torque. The Prelude has a bigger motor than you do for one thing. 200 HP/160 ft/lbs torque. Torque's what gets you going off the line.
My Vtec transition's barely noticable because, I believe honda did a better job tuning the transition on the '2k than they did with my R motor. Sounds like MAP or you're dropping out of vtec because you're low on oil.
Old Oct 20, 2006 | 10:16 PM
Berlina#2290's Avatar
particularly the 00-03's!!!??? im insulted!!!
Old Oct 21, 2006 | 02:16 AM
SpitfireS's Avatar
All of this has been covered before, maybe in other words.. but basically the same thing:
villeneuve Posted on Oct 21 2006, 05:36 AM
Most likely the ECU "learning" or adjusting to the weather => normal.
Don't tap the throttle.. let the ECU do its thing and it should become normal.
Like Ek9 mentioned.. Honda fine tuned the VTEC transition.
Also.. keep oil level up!
Sounds like the "MAP wack" to me too.
Don't wack it to bits
When was the last time you serviced the engine / car?
Air filter, valve clearence, throttle cable slack, spark plugs, oil change (gearbox + diff also).
There is more, look in your owners manual.
How are your shifting techniques?
Do you shift to late (hit the rev limiter) or to soon (don't reach the max HP / torque)
This is what I think
Old Oct 21, 2006 | 07:28 AM
villeneuve's Avatar
Thanks for your opinions guys..
i have the car since 2002 and know something wrong, im a maintenance maniac evryting is fine (oil,Air filters..), gotta change that map sensor this week or clean up the contact maybe , not a big $$ risk anyways.
i had to change the IAC valve because i had a check engine light whit the code 14 and a very buggy idle , 1500-1900 rpm, like if i push quickly trothle and release...sounds i had 2 problem at the ame time .
thanks !
Old Oct 21, 2006 | 07:54 AM
villeneuve's Avatar
YEp i beat the Lude 2001 SE of my freind EZ...but not these days , lol...
Old Oct 21, 2006 | 08:09 AM
dhayner's Avatar
He definitely should feel the VTEC kick under full throttle (with the engine warmed up). villeneuve has had the car since 2002 - he knows what it feels like. Something is wrong.
Old Oct 21, 2006 | 08:11 AM
Syncmaster's Avatar
Get your facts straight prior to posting, rather than simply posting nonsense.
Old Oct 21, 2006 | 08:23 AM
FISH22's Avatar
the vtec transition in the ap1's is outta this world. and whoever said its smooth, is damn crazy!
