vtec lag
Old Sep 30, 2009 | 12:25 AM
21k's Avatar
21k
Default vtec lag
ever since the instalation of my aem v2 cold air at random times my vtec doesnt kick in until 7-8k. i hear the cams change but dont get that kick until random times and sometimes the crossover is really smooth and i never even feel a kick. i topped up my oil but that didnt change anything.
Old Sep 30, 2009 | 07:32 AM
s2k aok's Avatar
Old Sep 30, 2009 | 10:23 AM
cougar hunter's Avatar
check/clean the the vtec solenoid screen?
Old Sep 30, 2009 | 12:11 PM
rob-2's Avatar
Reset ECU and re-learn idle?
You got enough oil in her?
Old Sep 30, 2009 | 02:48 PM
hughs2k's Avatar
that doesnt sound normal, you should hear your cai after 6k rpm.
Old Sep 30, 2009 | 04:17 PM
03_BB_S2K's Avatar
make sure your vtec controller is not set at 7K-8k
Old Oct 1, 2009 | 12:58 AM
21k's Avatar
21k
i have a v2 intake so anytime after 3k i can hear it. my oil is fine, and i unplugged my battery for 20 min. let it idle for 30 min, and drove 15 km. i read that will reset your ecu. it did fine tonight so im gonna chill until it does it again then ill take her to honda.
Old Oct 1, 2009 | 05:25 PM
Kirpich's Avatar
No. You didn't really reset the ECU. You need to:
1. Disconnect the battery.
2. Pull 'backup' fuse inside the car.
3. Replace the 'backup' fuse after 10-15 seconds or more.
4. connect the batt.
5. Do the ECU 'idle learn' procedure.
Old Oct 1, 2009 | 09:33 PM
let us know after procedure mentioned above
Old Oct 1, 2009 | 10:51 PM
21k's Avatar
21k
ok, im gonna go try that now.
