vtec sputtering, HELP!
Lately, my 00 s2k has been sputtering in vtec and I cannot figure it out. I know that vtec is regulated by oil pressure, so i went ahead and changed the oil to see if would fix the problem but that seemed to not work. Does anyone have any advice or suggestions for me. I can't stand driving my car without going into vtec. The sound just sooths my soul
shaggy and I had that problem in the car that we autocross -- the car would drive fine below the VTEC transition, but would cough and sputter above it. We eventually figured out that the problem was a loose spark plug wire which was vibrating out of contact, but only while in VTEC.
Good luck...
Steve
Good luck...
Steve
i use 92 octane always. i was thinking that it might be something with the coils or spark plugs. also what is a "map sensor whack"...I never go into vtec until the motor is fully warmed up. thanks for the input guys
Originally Posted by Squeezer,Sep 15 2004, 08:19 AM
I don't believe honda vtec is engaged by oil pressure. I believe when the ECU sees a certain RPM it enguages VTEC via the vtec selenoid. toyota's vvti-l system is based on oil pressure.
Originally Posted by shingles,Sep 15 2004, 08:30 AM
Not directly, but it makes sure that the oil pressure is above a certain level before engaging VTEC.
