Wack the map sensor
Old Sep 21, 2012 | 04:03 PM
s2kseven's Avatar
Default Wack the map sensor
I been reading a lot here about "wack the map sensor"
What does it means?
Is the map sensor being problematic parts in the s2000 and you need to bang it a little to wake up?
Old Sep 21, 2012 | 05:02 PM
MM3Kwolik's Avatar
"Whacking" it or "Banging" should really just be synonymous with "tapping". All you're really doing is loosening some of the buildup in the sensor. And putting the cable tie on there just keeps the harness clipped tight.
Wow...my first sentence sounds awfully sexual....
Old Sep 21, 2012 | 05:08 PM
s2kseven's Avatar
I'm new to s2000...sorry.
I've seen a few word "wacking" instead of whacking --- now I understand.
Thank you.
Perhaps I have map sensor issue too and in need of whacking!!
My car will idle momentarily and die. Good fuel pressure......most of the time just cranking no starting!!!
Old Aug 10, 2019 | 11:48 AM
Waynedru2000's Avatar
guys would a faulty map sensor send the car intoo limp mode i cleaned mine with carb cleaner as wel as the ICV and now the engine check light is on and it wont go above 3k when i drive it it will go above it in neutral but is very lumpy and it will not idle correctly now thought these measures were suppose to help not hinder our enjoyment.
Old Aug 10, 2019 | 02:55 PM
clio's Avatar
I don't think you should clean the map sensor with carb cleaner. I could be wrong.
Old Aug 10, 2019 | 08:54 PM
stock06's Avatar
Try cleaning again with Electronic Parts Cleaner (will evaporate), re-install. Replace or wipe clean the O-ring and Shin-Etsu it. Torque to 2.5 lbf-ft and careful not to drop it.
If this does not work, may need to be replaced. Hope this helps!
Old Aug 11, 2019 | 04:12 AM
Shin-Etsu it ?
Old Aug 11, 2019 | 04:23 AM
Chuck S's Avatar
Shin-Etsu is a brand of silicone grease specified (by name) by Honda for the soft rubber parts and seals on the car. Has Honda part number label ( 08798-9013 ) on top of the Shin-Etsu box. The noun has become a verb here.
Amazon Amazon
-- Chuck
amdaman
May 20, 2015 01:35 AM
s2konroids
Jul 12, 2010 12:13 AM
vteconly
Aug 18, 2006 02:18 PM
jason4207
Sep 2, 2005 11:10 AM
F1s2000
Dec 12, 2003 01:57 PM
