Washed Engine, a day later no start
Old Mar 4, 2008 | 05:09 PM
tampaSuzuka's Avatar
Default Washed Engine, a day later no start
I washed my engine Sunday...making sure to cover my alternator with foil and to NOT blast the engine with water. When I finished I drove the S around the block a couple of times with no problems.
Parked all day Monday.
Drove ~15 miles this morning no problems. After work car would not crank. Dash/cluster lights barely lit up with key turned to on position. It is like the battery was completely drained. It would not jump off of really old toyota tercel; finally worked when jumped off of a new tacoma.
However, the dash/cluster lights were flickering when driving around the parking lot. A few times the car lost power for a second or two.
It was raining and nasty out so I just left at a local shop overnight. I will have them test both the battery and alternator tomorrow.
Any other suggestions/thoughts in the meantime?
Old Mar 4, 2008 | 05:13 PM
BTW, I can't remember if the S has a battery light or not...
But I never got a battery light during all of this, if that helps at all.
Old Mar 4, 2008 | 05:48 PM
iDomN8U's Avatar
There isn't a battery light.
Electrical problems are the worse
It could be any number of things, but you're starting down the right path.
water could also be in a connector/ground.
CEL's on?
Old Mar 4, 2008 | 05:49 PM
EOE's Avatar
EOE
If gauges are flickering there is a good chance that it's your alternator.
Did you cover electric parts with plastic wrap or old bags before you hozed/sprayed down the engine bay.
Also did you use a hoze or power washer in the bay?
Old Mar 4, 2008 | 05:51 PM
BlownAP's Avatar
if the gauge cluster is flickering that means your alternator is on its way out.
but what i don't understand is why it happened so quickly, are you sure this flickering hasn't been going on for a while? your battery might have slowly been getting weaker and weaker.
Old Mar 4, 2008 | 05:59 PM
GT_NFR's Avatar
If you sprayed water directly into the engine bay without covering the Alternator then I would guess it is the Alternator as well.
Old Mar 4, 2008 | 06:36 PM
daktruckie99's Avatar
I was my engine weekly and never cover the alternator. But I never spray water directly on it either. Just gotta be careful not to soak it.
Old Mar 4, 2008 | 07:42 PM
Apex_AP1's Avatar
I was curious, what parts are required to cover when washing our engine bay?
Old Mar 4, 2008 | 07:43 PM
Nope, no CEL's.
Didn't cover any of the fuse boxes, etc. But I made sure to stay clear when rinsing.
I used the hose without a nozzle. So it was a low flow.
Old Mar 4, 2008 | 07:47 PM
I really haven't noticed any flickering...it does seem a bit strange.
