wat produces this sound?
Old Aug 26, 2003 | 05:19 PM
YOD88's Avatar
Default wat produces this sound?
wat makes the chirp noise that sometimes occurs when shifting in the s?
i don't own an s2k, im just asking because i saw a video clip of the car chirp in the shifting.
thanks in advance
Old Aug 26, 2003 | 05:39 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
What?
Old Aug 26, 2003 | 05:40 PM
BL00S2's Avatar
Spammer
Are you talking about the tires? If so, the chirp comes from the tires loosing traction.
If not the tires then the tranny which is grinding which is not a good thing.
Old Aug 26, 2003 | 05:44 PM
boiler's Avatar
Well, I don't know about anyone else, but when mine chirps in second gear, I see twin black strips of rubber about 6' long on the road.
Old Aug 26, 2003 | 07:05 PM
YOD88's Avatar
yeah i guess it was just the tires, like i said it was only a clip of a video, maybe if i see it again i can see if there is the black strips of rubber.
Old Aug 26, 2003 | 07:08 PM
RazorV3's Avatar
maybe the car had a turbo kit and you were hearing the BOV(blow off valve). it sounds like a chirp or woosh of air.
Old Aug 27, 2003 | 01:35 AM
bahula03's Avatar
i'm gonna guess it was a shift indicator (for lack of a better word) that chirps at a certain set rpm, i know a few guys have them on the board. It's pretty much like a shift light except it makes noise instead of lighting up.
Old Aug 27, 2003 | 07:49 AM
OC S2K's Avatar
The chirping he refers to is often the noise made when shifting and breaking traction.
Your tires mainly make the noise. An aftermarket clutch would make it easier to "chirp."
Old Aug 27, 2003 | 12:11 PM
bahula03's Avatar
Clarifying question; did the S chirp at every shift or just with the lower gears?
Old Aug 27, 2003 | 01:42 PM
YOD88's Avatar
it was in the lower gears , it chirped 1st to 2nd, 2nd to 3rd , and i think it was a little bit of a chirp in 3rd to 4th but not much.
